Good evening folks,
I was dropping in a remanufactured 302 long block from S & J and ran into some trouble. S & J says it is a 66-74 ford 302. Well when I went to put in my spark plugs they were too small from my 73 302. I think I bought some that were one size larger which worked. Then when I filled radiator w water, water was pouring out of corner of head and intake (intake is for a 302) towards the back passenger side. I removed intake and put lots of RTV and bolted down. This time water leaked at the passenger back side and passenger front side. I'm pretty sure I used enough RTV. Could they have put 351 heads on this 302 and hence my intake not sealing well?
I am pretty anxious to drive my bronco but could use help. If I remove valve covers, is there a part number or stamp that would tell me it's a 351 head?
Jeff
Jeff
