need help with a few issues
meathead333
Alexandria, VA
a couple minor issues have came up with my EB and like some ideas of what maybe wrong.
#1
i hear a hissing sound when i drive coming from behind the dash/engine compartment. i can here it also when i open the hood. it didnt use to be there. i havent done anything to my EB recently, so i dont think i did it by accident.
#2
about 1 month ago i replaced my wires, plugs, cap, belts, hoses and my father in law setup my timing. it was running real smooth, then, the past 3 weeks or so, when i start it up for the first time each day, it putters and will die if i dont rev the engine and give it gas for about 5 or 6 seconds. then it is fine. the only reason this worries me a bit is because it never did this before.
#3
another thing that has been happening is when i start it up and put it in rev for the first time to back up, i shift, then like 2 seconds later it finally goes into gear. then it is fine for the rest of the day.
obviously its getting cooler outside, so i dont know if starting the enigine cold is the issue. i just know that it wasnt doing this before i got out here to VA. any help would be great. trhanks.
RolledItAgain
If you have an automatic I would check/replace the vacuum line that feeds the trans. This could account for the hiss and the delayed shift.
oh2bnok
Olathe, KS
Check all your vacuum lines. THe ones that go to the carb, vacuum advance, everything. Sounds like one disconnected or has a crack in it.
jbeyer
new york city
check that big hose to the pvc valve, if you still have it. the one that goes from the back of the carb spacer to the valve.
