Need some help with 78/79 tilt column shift indicator
rjp1965
I have done an AOD swap and used a 1978/1979 auto tilt column.
Everything works fine except the shift indicator alignment. I'm clueless as to how to correct this. If anyone could give me some information as to how it works and how to adjust it I would really appreciate it.
Thanks in advance.
ENDLIFE
This an easy fix. Get an adjustable shift lever for your AOD, work your way out on the shift lever, this will cause a larger shift diameter, and align your shift needle with the corresponding letters. The bad news is you have to pull your valve body to get the shift lever in.
Good luck
