- Nov 11, 2007
- 8,223
what muffler you using? I want to know I have a V8, but I'm done with exhaust I cant hear over.
Do you know what the c4 problem was?
Put a tank of 93 in her and drove the wheels off her for a couple of hours... She likes WOT! Trans is shifting good, engine has a lot of power. Put another 75 miles on her- no top, kiddies in the back seat- a great day for cruising.
The exhaust, although louder than I really wanted, is not offensive when driving. Ran right at 190-195 degrees and when sitting at line in the drive thru it only got up to 200. 25psi oil pressure at idle when warm, 50psi when in gear running down the road.
It's nice to have it running again and I love to open the hood to show people the work.
I wish my c4 woes would disappear like that! Look forward to seeing it this coming weekend. Your motor build has given me some ideas for my blue 74 street rig. I will have to pick your brain.
Congratulations on getting the bugs worked out!
You have every right to be proud of that engine and show it off, you should keep doing it every chance you get!!!![]()
Did you use the bc broncos tank? If so what did you do for lines and filter?
Cruising around with your family, how it sounds at cruising speed, how it sounds when you get on it, how the tires hummmmm going down the road, are all lies until we see video!!!!!!! Yes, we love pics. Pics are awesome. But video, with sound, of a brand new 347 going down the road....... Sorry, I think I just had an organism......
Scott
You did right, your 347, I have the same goodies with my 331 it will work out with a custom tune will get the bugs out too mine cranks @ 36 then backs off when wot. The tune will deleat the stuf not needed and input new engine data ci, inj , mass air. jims cam specs rock , took a couple of mustang 347 dudes out truck runs low 12 got a mid 11 out of it very impressed to move 5,500 lbs with a 331. does it all @ 32-36 psi with 1, 225gph external pump. Eddy perf intake 1/2 spacer. Have fun great on the street.
First does the 347 keep the same exterior dimensions as the stock 302? Or do the heads make it more like the 351W? I have a 351W I did and it made my hydroboost, ps pump, alternator and hood clearance challenging.
Second, do you think the MSD Atomic Fuel Injection would have worked for your 347? Just wondering since I think my next build I am looking that way. 347 with the MSD Atomic. I know its a lot of money like 2K but every post I read from you it looks cheaper and cheaper.
The base idle will still be around 10 after the tune. Advancing it causes surging issues. The tune can add more total timing to make more power.
