englewoodcowboy
Lick Creek Restorations
- Jul 25, 2010
- 4,201
I am getting ready to start ordering parts for my engine build and with trying to hit an entire project completion build by April 2016 my biggest limitation is finances. I have been going through what I want, must haves etc. and having to ground my ideas based on is it really needed will it be used for example, I originally wanted to run Detroit True Tracs front and rear, then I thought about it, this rig will not see much off road other than the occasional two track etc. like at Cades Cove so I have dropped the expensive diffs for leaving the front open and the rear I will run a ford posi since they are the most affordable along with the need to upgrade to 31 spline axles just for peace of mind. With this mindset I am examining my motor and have decided on a 347 build and using a set of GT40 heads. I was hung on cams and stumbled across some other ideas as I have a 5.0 HO that I am doing the build with, if I use the HO cam and advance it 4 degrees, what other items should I replace or could I re-use? I am figuring new timing set but which one is best money spent, what about valve train? I could buy lifters, rockers etc should I buy new lifters? I want roller rockers as I figure anything to help reduce friction will add to some improvements elsewhere, should I change the ratio of the rockers etc.? I have a solid direction to head, I just need some wisdom in what to buy or save my money on. I have helped build engines before but this will be my first that I am doing myself. Any and all ideas as always are greatly appreciated.
Some added specs, I am planning on running 4:56 gears, 33" tires and an AOD. I have not bought gears yet so the ratio could be changed if need be to take advantage of other existing parts or ideas.
