new brake issue
zbronco
Houston
I have a 74 bronco with ford front disk conversion. The brakes have worked great until about two months ago. The issue at that time was the felt like the power booster was not working, could not lock up the brakes and you had to push the pedal to the floor.
So i replace the MC and the power booster. bench bled the booster, bled the brakes. typical stuff
Now the brakes feel like there are two stages. when you initially hit the brakes they feel normal and begin to slow the bronco, if you continue to push the brakes the pedal quickly travels another inch or two and the brake lock up. it is kinda like the power booster has a second gear.
I am pulling 19-20 lbs of vacuum off the manifold
I have bled and re-bled the brakes
I have tried the old MC (bench bled and bled brakes)
all with the same results.
I have attempted multiple times to contact company that sold the power booster (sponsor) and they have ignored my multiple attempts to get answers.
I know I should have started with CB for help...
any ideas? what did I miss?
Well first, if it's us, let me know so we can get something rolling. I'm not sure we can always fix everything, but we can at least make sure to give you an answer one way or the other.
Now, it almost sounds like your front and rear brakes are coming in at noticeably different times. Can you verify that your rear brakes (still drums?) are adjusted tight so the excess movement doesn't skew the results? An easy test for the rears would be to see how many clicks of the parking brake pedal it takes to make them tight.
And along those lines, if applying the parking brake pedal about half-way gets you a harder brake pedal, then you know the rear is delaying things.
Next, did you do the conversion or was it done previously? If indeed the Ford caliper setup, you might check the sliding surfaces to make sure they were clean of rust and flat/straight and lubricated.
Along those lines, there are at least two different designs of the anchor bracket and spring tensioners, and one size does not fit well with the other. So if there is a mismatch of parts there, the calipers can get jammed up after awhile. If they even worked in the first place.
Plenty of vacuum that's for sure.
What about a defective booster? Did you keep the old one by any chance? If so, maybe have it rebuilt locally if you have a place, and see how that works. The current crop of boosters doesn't seem to have the power we'd always like, but if there is a minor defect that could reduce it's effectiveness even more, that could create a real issue.
Where did you get the first booster? The second one?
Good luck. That's all I can think of to check for now. Hope it's a simple fix.
Oh, and what kind of plumbing do you have? Using a prop valve, or just straight to the old system? Prop valves can sometimes cause little issues too. Not usually like you're describing, but can't rule it out unless you don't have one.
Z
zbronco
Houston
Thanks for the quick response and direction. I will check on the rear brakes out this weekend and test as per your recommendation. The rear brakes are drums
The fronts look to be off of a 78-79 ford, I will make sure they are sliding properly
There is a prop valve.
The brake system was on the bronco when I purchased a couple years back.
The replacement booster did not come from wildhorse.. ( sorry next time)
given the strange symptoms and the issues started when the booster was replaced, I was thinking it was the booster. But I have never seen a brake system feel like it had multiple stages.
Thanks again for your help.
Timmy390
Conway, AR
Did you change the check valve on the booster? Guessing it came with a new one but new don't always mean good.....Could be the check valve is sticky giving you one stage when it's stuck then another when it opens.
Just a thought....
Tim
Apogee
Tangent, OR
Does the pedal have the same hitch in it when the engine isn't running and there is no vacuum being supplied to the booster, or is it only there when the engine is running?
What method did you use to bleed your master cylinder? Recirculation or plugged port?
Z
zbronco
Houston
The check valve came with the booster.
I used recirculation method on the MC
The issue does not happen when the engine is off.
thanks
