New brake kits
73azbronco
Not saying it's wrong, just dang, it's been a while since I priced brakes. I remember us talking here decade or so ago into cheap by finding $50 setups off the old trucks.
duffymahoney
Designing a brake kit is on my todo list. I don't like anything on the market and all are silly expensive.
toddz69
toddz69
I was a prolific puller of used parts (specifically backing plates and spindles) back in the day when so many of us were doing disc brake conversions. Hard to do stuff for $50 (unless a bunch of the parts were free), but $200-$250 conversions were well within the realm of possibility. Those conversions now with new parts are $600-$700 in a lot of places. The Wilwood/Baer stuff is all north of $2K, it appears.
I spent a lot less on my conversion than these guys are asking but it appears to be pretty complete.
Todd Z.
toddz69
toddz69
As a serious brake geek, I'm looking forward to seeing what you come up with!
Todd Z.
Speedrdr
Legend in my own mind
Paris, MS
Following as I would really like something other than factory E-brakes.
Randy
duffymahoney
Todd Z.
I would use the Brembo CTS-V calipers. Which are 300-500 a set used and can be bought new. Sexy caliper with huge stopping power. But require a 17" wheel
Jdgephar
My '04 Acura TL (manual trans) uses Brembo brakes...less than $80 a side, aftermarket has even cheaper ones. It's a 4 piston design, but no idea what it would take to put on a Bronco, or what size wheels. I believe the Acura is on 17" wheels, but I'll have to double-check.
toddz69
toddz69
Reminds me of the Brembo ATS calipers kit from S&S Engineering that is so cool to do on the Fox bodies for not a lot of $$. I've not looked at the piston diameters in the CTS-V calipers to see how they compare to other setups out there. The ATS calipers' pistons are too small for use on an EB, imo. If the CTS-V's have a good piston area, they might be a good option.
Todd Z.
73azbronco
Todd Z.
yeah i built myine out of fullsize bronco parts when they were $50 for brakes calipers and spindles and stuff. Now Ebay guy wants $200 just for spindle
Shimmy
1977 Bronco
Maple Valley
curious how much brake bias matters with these early broncos and if any of the existing BBKs have calcs to share?
Yeah, I remember getting my whole F150 Dana 44 axle, with all the brake components, for $200.
Used everything and sold the rest for $250.
Not much of a wheeler dealer myself, so felt pretty good about the whole thing.
Big Slim
i have been looking at a similar set but a bit smaller rotor to fit in 15" wheels. brakes
yea. almost better to get a new axle and shorten it than just a brake kit. then get brake and axle upgrade!
Hopefully a new brake kit will have parts we can source from parts yards to keep the cost down.
even a VW Touareg has 6 piston calipers. plenty of nice calipers out there, just a pain to get any of them to fit.
toddz69
toddz69
I think it matters - I'm guessing that not many (or any) of the brake mfgs. have numbers to share. Lots of variables due to rear brake configurations. In looking at something to compare my truck to from an OEM perspective (SWB 4x4 with 4 wheel discs), I ran the numbers on Jeep JKs (and maybe TJs) and D90s. The Jeeps have more rear bias than my setup but as I recall (I have it all written down somewhere), but my setup (Dodge front calipers/Explorer rears) is almost identical to the D90.
Todd Z.
duffymahoney
I have a custom kit setup for my 240z. It's not cobbled together, it's engineered with stop tech for perfect bias, pedal feel and stopping. It's amazing.
toddz69
toddz69
I have a custom kit setup for my 240z. It's not cobbled together, it's engineers with stop tech for perfect bias, pedal feel and stopping. It's amazing.
StopTech used to have some awesome kits for the newer Z cars as well - maybe they still do. They had one of the best brake engineers in the business, James Walker Jr., working for them at one point. Did StopTech put together your kit or an aftermarket group?
Edit: I see where they put together your kit:
https://www.facebook.com/zcargarage...do-it-yourself-installatio/10156498722656524/
Very nicely done!
Todd Z.
jamesroney
Fremont, CA
Zcar and Stoptech worked together on it, is what I was told. The calipers are the same size front and back. But the bias comes from the MC. My bronco front bias, fancy brakes are my next big project. It's just a large undertaking.
Uhm, I'm not sure that you mean what you are saying here.
The Stoptech kit is elegant, and should work great with the spot caliper as a parking brake. But to say that the calipers are the "same size" is a little bit misleading. The calipers may well be the "same size" on the outside, but the pistons inside the calipers are carefully selected to provide the correct proportioning. The brake bias cannot come from the master cylinder, as it is a single bore 7/8 dual master. The brake bias comes from the fact that there are tiny pistons in the rear caliper housed in an enormous caliper. The Stoptech solution is elegant and does not require a separate proportioning valve but it is evident from the picture that the caliper pistons are much smaller.
@toddz69 will understand that I'm not saying anything negative here. I do like the solution. (mostly) But it is over-constrained with a single bore Master cylinder, and brake bias has to come from somewhere.
duffymahoney
Interesting, I didn't see the pistons being smaller when I installed them. I thought they were identical. Nice find!
snipes243
Huntersville, NC
Todd Z.
I'm curious what you did you for your conversion?
markw
Interesting thread. I’m build a new race truck. Stock D44 front axle. Any suggestions for brakes? Limited to 15” wheel for Pioneer class. I’ve found EEC Yellow pads make a huge difference no matter the application. Thanks, Mark
