New Guy Build
PROJECTJUNKIE
Hi, I'm the new guy;) I have a 67 bronco that has been sitting since 1984 and want to swap in a EFI 5.0, an overdrive auto, convert to power steering and disk brakes and put aluminum wheels on it. I want front and rear bench seats, with leather. I hope to do the swap for about $1k, but I have a bunch of junk laying around that I can use.
robofig
Paint the bronco like a tiger and we will call him Siefried or Roy.;D
roccolukasik
Ohio Michigan border
bought my bronco for $5,300.00 figured I would finish it with a total of $8,000 to $10,000 I have done most all of the work myself with my father am still not finished and skimming through reciepts I am in for around $20,000.00 beware the bronco eats time and money!
VBH289
Colorado
Go to a junkyard and see if you can find a rear-ended late fox body Mustang GT or select LX cars.
P
PROJECTJUNKIE
if you do that for $1k, you need to change from "new guy" to "david copperfield"
;D
I've been sitting on this for 5 years, waiting untill I got the time and money to build it right. It has 1984 tags, and has 89k original miles. Original owner left it to son (or grandson?) who sold it to family friend, who did tune up, oil change, and put a set of used tires on it to move it around. I will be the 2nd owner to register it. When I got it I put a $10 fox body radiator, crown vic water pump and alternator in it from a $100 car me and my buddy went halfies on. The tires are 31" BFGs with 95% tread. I had a jeep with nice 33s, and got a screaming deal on 35s, then I saw a lifted jeep in my neighborhood looking like a roller skate and banged on the door. The kid gave me a nice custom jeep bumper, $100, and these tires, he worked at pep boys, so he mounted and balanced them;D
The wheels are from a $700 96 F150 project truck I will be selling soon, which now has factory chromies from my 95 bronco, which now has chrome mods left over from another early bronco. It cost me an 18pack to use the tire machine for the morning;D and I'll count that against the F150 cause I had to mount up a set of used tires anyways.
I replied to a "C6 wanted" ad on craigslist, and offered a "running when pulled" 2wd BB C6 to the guy for $50. A friend was cleaning house and dropped this off a couple of years earlier. The guy picks it up and gives me $50 for it. We are BSing and I tell him I'm looking for an NV3550. He asks me what I'm trying to do, when I tell him I want OD in an EB he informs me that he has an AOD that he bought for a musclecar project, and it had a D20 on it, I can have the adaptor for....... $50:D He shoots me some pictures, and sure enough its an Advance Adaptors piece, for early aod, and is complete. I tell him I'll give him his $50 back. It is in great shape, but there is a little crud in the roller bearing, which if I cant work out, I'll replace.
On the way home from his place I stop to check out a possible donor car.
Here is my $250 86 mustang, ran and drove, but bad paint and no title. EFI 5.0 and aod. Compression tested 147-160, tranny pressures were spot on. Towed home, swapped a tire over and ran up and down the road at 70mph. A guy is buying the rear end for $150 tomorrow, and the rest will be on ebay. The convertible parts should make my $$ back pretty quick.
4 years ago I put full width axles and a F250 box on my 71 EB. I have the bronco steering box in storage, and my axle donor truck had a GM D44 in the bed (I used the backing plates and calipers on my highboy) but still have the spindles.
I have GM backing plates I bought from a guy for $20.
I got a set of loaded GM calipers from a friend, left over from a project, one of the goes around comes around deals, we don't really keep track of who owes who. I spent some time cross referencing hub/rotors and found that they are all the same 75ish to 87ish. These went way up in price, I'm not paying $200 a side. We don't have much for junkyards around here, I mostly buy parts cars and piece out the rest, but I only needed hubs/rotors. I hit the pull a part and found a 1980 F150 with rusty rotors, rotors are cheap, hubs are expensive. Set out a floor mat and pulled the hubs apart, then reassembled with lockouts (I have misc used lockouts around, but really wanted to get a full set and not have to dig for parts). These cost me $40, if I hadn't have bolted the lockouts onto the hub, he probably would have hosed me. Dropped off at checker and had them turned, I know the manager and she used new bits, and did a really good job. Cost me $20. I was a little pissed about spending $50 on brake hoses, and was putting that off. While moving some things around at my dads place I looked over at the GM D60 I've been holding onto for my highboy, and its got hoses on it, sweet. The truck already has GM calipers and hoses, so they will not be needed.
As for the interior, I got a backseat from my buddy for $20 a while back, but needs new wood and upholstery. Same friend introduced me to his sister, now we have 3 daughters, and need a front bench seat to fit us all. I have a basketcase 68 EB that has a front bench in it, I'll pull that to have reupholstered.
I'll get some more pictures and put them up.
Stangfather
Oklahoma City
well when you put it that way LOL
is the 86 CFI or cali model with EFI/Speed Density, if its EFI, your in luck, CFI is a joke and doesnt handle anything more than the stock cam and airflow specs.
P
PROJECTJUNKIE
I've been saving some parts for a while, and when I see a deal, I jump on it. I've found that I never have time AND money, always one or the other, so when I have $$ I buy parts so when I'm strapped, I still have something to do, or something to sell. My OT got cut, I work in mining and am lucky to still have work, so this will be a budget build.
The motor:
The master plan is to find a nice explorer motor, get a new cam, reseal it, run it with the mustang efi, ign, and preferably the sploder serp stuff. But for now I'll run the mustang motor to get the bugs worked out.
Its SEFI, and good running. I don't see anything on the car that has been modified. It was either a babied 197k or a run hard 97k. It had a lifter tick after sitting for 2 days, and smoked a little, but the comp checked out good, a wet test only picked up 10% compression, so I yanked it, pressure washed it, and will drop it in with new oil and plugs.
Tranny:
I'll put some time and money into the trans, as it will be permanent. The seller said that sometimes it hunted between 3rd and 4th on the highway. I have never rebuilt an AT, and wouldn't be able to identify bad parts, so I wanted to identify any symptoms and research how to deal with them, before I cracked pandoras box open. The donor car has wasted tires, has the temp spare on it, and came with a dismounted tire in the trunk. I mounted it up, and roadtested it. I got up to 70 mph, no hunted, slipping, anything to indicate any problems at all. I did find that roadtesting $250 5.0 mustangs on dirt roads in the rain is incredibly rewarding, after owning 3 mustangs, creeping over speed bumps, stopping short to not hit parking curbs, this was a nice change:D
I ran into my neighbors/cousin inlaws heading into the desert on quads, wanting to see some donuts. The last donut left me nosed down in the ditch, high centered, spinning baldys on the dirt trying to back up. I'm in a $250 car, so I slam it in drive, mash the gas and cut it hard, riding the ditch for a good 300' till I had the speed to climb out, full spunoutinthegrassnotgonnagetlappednascarstyle. The inlaws and I were quite impressed.
I bought the $20 autozone "how to rebuild ford automatics" book and got to it. I dropped the exhaust and hooked up a borrowed pressure gauge, and the pressures checked out against the book specs. The case had some yellow marker on it, I was thinking JY trans, but the last half of the VIN is stamped into the case, so I figured it had been out of the car for a rebuild at some point. The pan was surprisingly clean. I didn't have a slide hammer to remove the pump, so I bolted a piece of chain to the puller hole and gave it a couple of yanks, worked fine for me. The seals on the pistons were fresh, the 2-3 accumulator piston was an updated part, and the intermediate clutches still have the branding printed on the wear face, so this tranny is fresh;D
My searching says the 3-4 hunting is likely due to misadjusted TV cable, causing low line pressures, which can cause the direct clutches to go out, which will cause serious 3-4 hunting, and eventually loss of 4th and then 3rd. I will disassemble the direct clutches and check for excessive wear. At this point I will need the "ring seal kit" for the tailshaft, I may be able to take them off of the car shaft, but not so sure it worth it, I need the extension housing gasket and seal, upper valve body gasket and some D20 seals. I also want to get a shift kit while I have the valve body out. I talked to a builder at the supply house, he told me that the OD servo pistons are lettered, like A-D, As and Bs give higher OD apply pressures and Cs and Ds are softer and will burn up the OD band. This stuff is starting to make sense to me. Tomorrow I will be cleaning, inspecting and ordering AT parts.
Misc:
I will use as much of this car as I can. I need to research throttle and TV cables, VSS with speedo cable, and find a reverse flex fan. It may be worth looking into a good electric fan, I'll have to chew on that. I think I have a PS hose laying around that will work. The EB has headers, I'm not sure if I should just weld O2 bungs in them, or try to fit the mustang headers. I need to eliminate the EGR and air pump stuff from the engine. I made an egr block off plate at work, and will probably pick up the fordfuelinjection.com EGR eliminator, or build one myself. I have twin fuel tanks, and really don't want to put inline pumps, accumulator tanks, etc etc in this. My 71 EB has a healthy efi 351 fed off of an inline pump alone (E2000?), I may go that route, but need to check the reliability of it. I'm thinking that possibly the easiest/cheapest/reliablest setup may be to modify the rear tank to use the mustang pump (scab the top of the mustang tank on to the EB tank if I have to), run the pressure and return lines from this tank, and use a low pressure pump (I have one) on a toggle switch to feed the fuel from the front tank into the rear tank. Lots of later model GMs are set up like this.
Stangfather
Oklahoma City
weld the 02 Bungs on.
and for what its worth stock 5.0 mustang "headers" are that in name alone,the are pinched at the port REAL bad, plus the are short.
P
PROJECTJUNKIE
Do the mustang headers fit and not interfere?
The factory headers are not known for the performance, but I've never had one crack or blow out a gasket. When I pull the 289 I'll look the 40yr old headers over real good. They are the style that wraps around the pass motor mount tower, I had these in my highboy and hated doing gaskets and starters. I'll to a little more research before deciding on this.
P
PROJECTJUNKIE
So I sold the rear end out of the donor car for $150 last night, sold a taillight for $20, and found $5 worth of change, so I'm only in it for like $100;D
Went to the local Hughes Performance parts distributer this morning to get some parts. The lady (owner?) was really nice, looked over my valve body and bands (I had my doubts) and helped me decide what to get, and when I told her it was going into an EB she turned into a sweetheart.;) Apparantly she's been wanting one for some time. The rebuild parts were priced competitively with the internet pricing I got, but the shift kit and the reverse boost valve were like 50% over my other quotes. I told her I prefer to shop locally and support small businesses, and will pay extra for service, but still need to stay on budget. She checked her pricing, and was able to knock about $25 off of the total, down to $160. I got great service and good pricing on high quality pieces. I asked for some stickers, she got me 2 big stickers and a hat;D I'd definately recommend them, just tell her you have an EB!
I'll get some pictures up later.
b4opec
Sausalito, CA Marin
Is this a real thread? It seems far too funny to be real. All you guys giving advice; new guy's got a lot to say and seems to have all his own answers!
The bench seat for family of 3? Come on!
Hilarious!
robofig
Hilarious!
X2 on all his own answers. %)
P
PROJECTJUNKIE
Hilarious!
Glad I could entertain you;)
The front bench seats 3 right? So with the rear bench that gives me 5 seatbelts.
I've got a pile of parts and half a plan.
If you've got suggestions, I'm all ears!
