flaagan
So the old ignition pretty much fell apart when I removed it from our '68, but it worked when it was in.
I ordered and received a new switch, and when I plugged it back in the same way it was before the starter would run at the "On" position and I can't get the car started. I've tried figuring it out but the wiring doesn't match up with what's in the shop manual.
In the vehicle, it had the black, violet, and yellow lines matching up with where they're supposed to go according to the manual.
On the "C" plug the vehicle had the pink wire, which in the manual is listed as supposed to be a green wire with red stripe and a red wire with green stripe.
On the "S" plug it had a red wire with blue stripe and a red wire with yellow stripe, where the manual says it should be a blue wire with red stripe.
Help?!![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Help?!
