New motor, same problem.
Okie69
Okie69
If you look at the picture of your old carb the distrubiter vacuum should be hooked up on the fitting under the front bowl on the drivers side. It looks like you have the vacuum hooked up on the passengers side of the carburator. That is full manifold vacuum. It will screw up your vacuum advance and your timing settings for the distributer. Fix that before making major changes.
Wow I hope that's not the cause...at the same time I kind of hope it is. Thanks for the advice!
Okie69
Okie69
Well, there's not another vacuum port on the carb...?
broncodriver99
Glen Allen, VA
If that is a 2100 that is the ported vacuum nipple and is hooked up correctly. It may have moved on the 2150 but that is the only port on a 2100/4100.
Okie69
Okie69
broncnaz
Im pretty sure thats a 2100 and I believe even the2150's that port is ported vacuum not full vacuum. Anyhow if in doubt just pull the vacuum hose when at idle if the idle speed goes up and you feel vacuum on the end of the line then it may be full vacuum.
Okie69
Okie69
Well... New carb is installed now it runs worse than it did. White smoke and even worse sputtering. I think it's flooded like crazy and it won't idle now.
half cab
Guru Bronco
Oops......man I know this has got to be very frustrating!!
Okie69
Okie69
It really is, and I don't know where to go from here. One step forward two steps back
mcknight77
Caldwell, ID
I'm late in this, but did you put a timing light on it to confirm the distributor is advancing when you rev it up? If it's not advancing it will be weak on power and very slow to rev up.
Did you replace the base gasket with the new carb?
Okie69
Okie69
New gasket and yes it's advancing correctly. I don't understand why a new carb would make it run substantially worse. Thanks again to everyone who's taking time to help me out.
Okie69
Okie69
I'm going To compression test tomorrow see if the new motor is doing what is supposed to. Any ideas where to head from there?
treihesse
Do you have new plug wires? Im gonna say you have a fuego problem. Are you running points or duraspark or a pertronix?
broncnaz
White smoke tends to indicate water. So you either have a issue of the intake water port leaking into a cylinder or you have water in your gas. Of course white smoke can just be from water in the exhuast system so intial white smoke that goes away is not a big deal.
Okie69
Okie69
New plugs and wires, still running the points.
The white smoke also likes to shoot out of the carb when it starts sputtering if that's an indicator of anything.
treihesse
That sounds like way to much timing advance. I always loosen the bolt have somone start it and turn the distributor until its close. Could be a stuck valve.
Okie69
Okie69
So that would mean it was firing too early or late and pushing gases out of the carb?
Or am I way off? Haha
