chuck said:The door locks are in stock now. they are $50 for the power door locks and an add. $30 for the remote part. So $80 for the power remote door locks. The power D/L work when you lock/unlock the driver door the pass. door will lock/unlock. The remote works from a wireless remote.
Look at the end of your door, you will see a 7/16" bolt head. That bolt holds the bottom of the window track in place. Jason made the bracket (blue in picture) to bolt onside the door between the door and the window track. So the bracket is mounted near the bottom of the door so would stay in the door if you remove the window frames.Sac '68 sport said:Great Idea!!! Been looking at some of the street rod mag's trying to figure out how to do it.
It was sort of hard to tell from the discription where/how they mount. Sounds like it uses one of the window frame bolts in the door? Will it work with the window frames out for those of us that take them off in the summer?
Yes a 2 door set. Also to make it clear, when you lock/unlock either door the other door will follow. To sign up either go to the online store and order or call.HotWheels said:we are talking a two door set right? where do I sign up?
I have no idea about this. How can you tell how secure it is? Also how secure should it be?HotWheels said:...btw how secure is the frequency the work on???![]()
I don't know this one either. The little box in the picture is the "brain" to use the remote you remove that box and replace it with the one that comes with the remote. My guess is you could wire it to your alarm system by removing the "brain" and wiring it to your alarm. My concern is the 2 door working together if you remove the box. I will check with Jason when he comes in later today and he can have a look at the instructions to see if there is any info there.Hnrys69 said:if we already have a alarm with a door lock/unlock output... is the 50 dollar job enough?? I mean, does the driver side have an input for a power option?
