New shocks. HELP!
Robster
I need to buy new shocks. I only drive on the highway and never off-road. I have 35x12.5x17 toyo RT tires and double shocks up front and in the rear. Bought it this way. I want a comfortable ride. What do you guys recommend? Thanks a million
sstlaure
Bronco Slacker
Personally - I've found a crappy ride is more a function of springs that are too stiff rather than bad shocks.
Agreed. At the very least remove one shock per wheel and try that for awhile.
Also check air pressures in your tires. Chances are pretty good that they're too high which will lead to a harsher than needed ride.
And frankly, the recommendation for Bilsteins is right on target too, as virtually all the feedback we have gotten so far has been positive.
But getting rid of one each initially will only help.
Oh, and along the lines of what sstlaure was saying, do you know what springs are on there now? If old-school stuff (or even just old) then the ride is likely to be unnecessarily harsh due to the springs too.
JefeAZ
Tucson
Crap ^ I was just convinced to go with dual shock hoops on my LUBR. No offroading but some light trail running and 40-50mph through harsh city roads. Maybe Bilstein will have something for this setup.
No hard top so hopefully it doesnt make it even more of a rattle trap. I guess it will look cool...haha
Ya I just went from Duff 2.5" to Deaver 3.5" coils. Night and day ride quality difference. New tires were also a big help
sstlaure
Bronco Slacker
True but double who knows what ratio shocks don't help at all.
For sure - but shocks primary purpose is to provide the damping of the spring force to prevent them from oscillating when they are compressed.
If the springs don't compress, then shocks or no shocks it will ride like crap.
wegngis
Oregon
I put KYB Gas-a-justs on mine this year. They're OK. Still a bit bouncy, but better than completely shot shocks.
Well don't give up completely on duals just yet then. Some of your driving can justify it, while much of the normal driving does not.
For one thing, front hoops are like an inadvertent "strut tower brace" for a Bronco. Adding some rigidity to the frame and coil towers. That alone tightens things up slightly.
If you do go with duals, simply opt for some that have slightly lighter valving (maybe about 20 to 30 percent?) and that might do the trick.
But first, with your stated use and lighter rear end I would just try off-the-shelf Bilsteins and see what you think. Yes, it's a not inexpensive investment in testing, but it's been so good for so many that you might just like it as much as you did when changing the springs.
sstlaure
Bronco Slacker
You could always just pull both shocks and see how it rides without shocks (not that you would drive/leave it that way) but at least you could see if the springs are the main source of your harsh ride and it would give you an indicator of how much damping you may need.
