I have been chasing down and cleaning up some minor electrical bugs on my 73 bronco. All marker lights are working. Headlights and tag lights work. Front turn signals both work (drivers side you have to apply pressure on signal lever). Tail lights both burn when headlights are on. Problem is neither brake light works and the left rear turn doesn't work. I know there is power to rear brake lights because I removed the rear housings and when they are at different stages of being screwed back in and grounded they will burn. By the way all have new bulbs. I have also seen the left rear flash but not when everything is back together. Any suggestions?
