If ya don't find anything wrong with that fuse link, then I'd say its probably time to start cutting down the circuit.
Seems to me a good starting point for that would be to go from battery positive directly to your starter. Make sure you're in park or neutral (and try not to touch anything metal with your skin) and just touch the battery positive cable and the starter cable together real quick. If it sparks and makes some noise, then great, your battery cables are good and can carry current! Your issue is elsewhere.
If not, try quickly tapping the positive cable to the negative terminal. If no sparks, then your positive cable is bad, or something really funky is going on with that battery of yours.
If that sparks, then you have current through the positive cable. That means that either the starter wasn't grounded, or the battery wasn't. Disconnect your battery ground cable from the block and tap it to the end of your battery positive cable. If that sparks, then all your cables are good, and either the ground to the block or starter were bad. If no sparks, your battery negative cable is shot.
Remember, a test light is (generally) really low current, so just cuz it can light up don't mean your cables can carry what you need them to!
Good Luck, and don't hurt yourself!
