Hi all,
Well, just bought myself a 66 half cab and am trying to get it started. More specifically, just to turn over. In the RUN position, I have no voltage to the solenoid or to the ignition coil....What could be causing this? Where does the ignition get it's power from? I have 12 volts at the battery.
What I am having trouble tracing is the yellow wire from the ignition switch....where it goes, what it does. The yellow wire seems to be corroded and bad. I have the diagrams from N8's page but they don't seems to clarify much if you don't understand the basics. Is there a possible problem with the fuse box???
Any tips would be helpful....Thanks!
