Boyd Jaynes here, it seems we weren't invited to the party but nevertheless I’m here, better late than never I guess. I’m sure my racing partner Brian Godfrey will have his own .02 cents to add as well.
I bought my Bronco on Craigslist in 2008 specifically to race NORRA. It isn’t a Stroppe, it never raced, and it wasn’t frame off restored before we started racing it. I spent every dime I had to make it to the startline every spring. Even if I had trouble paying my rent I would still enter the MEX1K. After 10 years of racing at NORRA I have invested not only my hard-earned money but also vast amounts of time into how to make our truck better…, WITHIN THE RULES. I didn’t ask for the rules to be changed when I couldn’t figure something out…, and when the rules did change (2.5” to 2.0” shocks) we made the change at considerable expense in order to remain in the class for which our truck was designed. It took countless mistakes, a couple of years of being dead last guy in the field before we started to figure it out. We read the rules and built a truck based on them and were always considerate of the way they raced back in the day. We didn’t have a wealth of Bronco or vintage racing knowledge to fall back on, I didn’t even own 3 wrenches when I bought my Bronco, but I was eager to figure things out. Now, while everyone wants to talk about the spirit of NORRA, this conversation, a discussion about what should and shouldn’t be allowed, on an online chat room... is really NOT the spirit of NORRA. If you think a rule change is in order because after a couple of races you didn’t get the results you wanted, then perhaps competitive sports isn’t for you. How about come back next year smarter, better prepared and try again. The rules that have been in place for pioneer for ten years are pretty fair, definitely need some clarification in areas, but pretty reasonable. I for one don’t want to be forced to race in another class (with vehicles that are more modified) because all of a sudden the rules aren’t working out for some people. Apparently a lot of the rumbling in regards to what is “fair” and what isn’t, comes from the other Pioneer era classes. Where do we draw the line in the quest to “level the playing field”? Where does the definition of “stock” & “vintage” intersect with what is known to be period correct, the availability of old parts and what is safe? I don’t envy Chris Wilson who has a tough job listening to what seems to be a sudden avalanche of whining from racers as he attempts to hone the rules a little better. It isn’t just in Pioneer either, it’s merely a sign that the happiest race on earth… is also an ACTUAL fucking race.
So now a catalog of what apparently some of you think are “trick parts”...
Let’s start with shock heat exchangers. If you think a finned vessel that your oil goes through to attempt to scrub some heat off is exotic, then you must be easily impressed. You may notice that we only have one shock per wheel rather than 2-3 like most of the other competitors. For us to stay within the rules and not break the bank on refab-ing the truck we elected to use heat exchangers for simplicity. We actually took off the heat exchangers from the front shocks to further simplify the setup. Again, shock coolers are not exotic, not hard to get (Fox and King both have one available), guys made them by hand back in the day.
Shock length / Travel
Stock length leafs, shackles, intact stock coil buckets, and no modification to the frame will limit travel. If someone wants to lift their Bronco to the moon and think they are going to have more usable travel, they are mistaken and will probably be out of the race on the first day. Even the Bluetorch Bronco which is supposedly the benchmark for period-correct admittedly doesn’t have “stock” shock mounts. I do agree that stock pivot locations should not be changed to stay within the pioneer class. The bottom line is a longer shock isn’t going to miraculously provide more travel and all of us forced to run an interpretation of stock, seems ridiculous. The rules as they are written will limit usable travel. Any additional rules will just create an opportunity for any real racer with ingenuity to interpret for a real advantage over what was conceptually intended (more rules = $$$).
Engines should be carbureted, I don’t think there is really any question that this is the right thing for pioneer. I have a 302 block stroked to 347 with a carb. Actually a pretty mild powerplant running on pump gas through a notoriously weak-link, a C4 transmission. I would say to anyone with a similar Bronco to what we all run at NORRA, who thinks a ton of HP will win this race… good luck, go for it.
Radius arms are zero advantage unless they are longer and/or connected via something other than rubber donuts. We are going to put the same old stock (bent) pair we ran for 9 years back on and not think about it again. Radius arms don’t make you faster.
Yes, we have Wilwood brakes. Apparently ‘yall have a case of brake envy I read so many comments about them. We couldn’t get the ones we had before to work, so we threw everything we could at our brake issues to try and be safer. We couldn’t get the fancy Wilwoods to work very well either for the first 2 years and now after literally years of trial and error (risking life and limb) we finally have decent brakes. Rules should never be changed to force any of us to use “vintage” or vintage approved, “period correct” brake kits from dubious recreational bronco suppliers. We drive the piss out of our old ‘68 and the brakes keep us from dying. If they fit inside a 15” rim you should be allowed to use them.
This brings me to my final point.
We work hard all year on our program by making and maintaining relationships with companies that help us show up in April to race. We are marketing guys in our day jobs, that is what we do. Some of you are Bronco experts but we don’t mock your knowledge because we think it gives you an unfair advantage. If anything, we have done our job too good. Because of our efforts, you guys all think we are some sort of trophy truck team. It’s myself and Brian. That’s it. We have to keep moving the Bronco between our two tiny garages because we don’t have a proper shop space, we don’t even own a welder. I see the workspace most of you enjoy and I’m jealous but not envious to the point of malicious. We have had success because we come prepared and we don’t break our shit. Our trucks are all VERY close in configuration, power, and have similar performance limits. Let’s sort this out and continue to race together!
VIVA BAJA
-Boyd
PS. if any of you would like to come have a look at our truck and point at what they think is an unfair advantage, "trick" or "exotic" parts then come on over but you better bring some beer.
