This thing is driving me nuts, I have a new inline fuel filter right before the carb. Just replaced manual fuel pump (because I thought that was the problem). A few months ago I changed out the float/filter in the gas tank.
While the engine is running/idlle I can watch the fuel in the filter raise to full and in a couple minitues it will drop to almost nothing in the filter. The motor still runs. I can push the throttle and race the engine up a little and when it come back to idle it will start to fill the filter up again. Sometimes I dont have to race the engine and the filter will fill up again... the it will drop to almost nothing in the filter. There isnt' any rhyme or reason behind it. I dont have any gas leaks, I chased the gas line from tank to fuel pump and everything looks good
But it does have an aux tank which is not hooked up, and was thinking MAYBE that valve is clogged or causing problmes..I turned it a few times and heard it click but nothing seemed to help. Maybe I have trash in the pickup in the tank?? Thats the only thing I can think of...Any suggestions??
