Not getting enough gas/unstable
kat
Bristol
This thing is driving me nuts, I have a new inline fuel filter right before the carb. Just replaced manual fuel pump (because I thought that was the problem). A few months ago I changed out the float/filter in the gas tank.
While the engine is running/idlle I can watch the fuel in the filter raise to full and in a couple minitues it will drop to almost nothing in the filter. The motor still runs. I can push the throttle and race the engine up a little and when it come back to idle it will start to fill the filter up again. Sometimes I dont have to race the engine and the filter will fill up again... the it will drop to almost nothing in the filter. There isnt' any rhyme or reason behind it. I dont have any gas leaks, I chased the gas line from tank to fuel pump and everything looks good
But it does have an aux tank which is not hooked up, and was thinking MAYBE that valve is clogged or causing problmes..I turned it a few times and heard it click but nothing seemed to help. Maybe I have trash in the pickup in the tank?? Thats the only thing I can think of...Any suggestions??
POPPAWS BRONCO
Horn Lake, Ms.
May not be what you want to hear but electric pump with solve all of the inconsistencies unless you have trash in the line. You could try to blow them out with air pressure. My 77 has always had fuel problems. It was one of the reasons I went to EFI and at that time replaced from tank to intake manifold. As I still had the factory two barrel intake and carb. Now that's going Extreme for your problem but before I inherited the Bronco my whole life was spent replacing fuel tanks lines Manuel pumps rebuilding the carbs ect. And I just wanted it to be more reliable.
Hey!!! Let me hold a dollar I'm in the middle of a restore here!
SHX669
Not an uncommon problem ; does it still run ok - good - well - when you stomp on it or run at high rpms for awhile ?
The floats in the carb are only going to let in the amount of fuel that your motor requires { in theory }. I'm thinking it has to do with the way mechanical pumps work - they suck fuel- pull a vacuum on the fuel line . Then push against existing pressure and i'm not sure if there's an internal bypass or not.
I actually had more problems with electric pumps having varying fuel pressures -BUT- that might have been caused by faulty wiring and plumbing installs.
phred
Earth
As long as the truck holds idle it's fine. Like SHX669 says as long as the bowls are full in the carb the no more full can flow in I've experimented with mech and electric pumps and the carb controls the amount is flow. Both my trucks rarely have more than 1/2 full filters while the engine is at a resting idle.
Timmy390
Conway, AR
The filter before the carb (Street Avenger 770) on my big block 390FE Mach 1 does the same thing. Sometimes it's full sometimes almost empty but it runs like a scalded dog so I don't worry about it.
Tim
kat
kat
Bristol
Thanks for the encouragement. It runs down the road fine, but if I get into the secondary it stutters sometimes. It does seem to idle fine..but difficult to start when warm. BUT I think it may be a timing issue I have no timing pointer but have one ordered along with some timing tape
jckkys
The whole problem can be traced to the clear plastic filter. These serve no useful purpose. The amount of fuel in the filter is irrelevant and they're a fire hazard. Ford and Holley carbs usually have screw in steel filters and AFBs can take an in line metal filter. The problem of less than adequate fuel delivery, would be apparent in climbing long grades or in passing scenarios. In my opinion EFI is LESS reliable than a carb, and harder to fix. Especially in the middle of nowhere. Secondary throttles opening too soon, will cause a stumble. This is addressed differently in different carbs. There's no reason to use an electric fuel pump. They're noisy and less reliable. I get about 20 yrs. out of a mechanical pump before the seal wears and crank case oil sprays out of the vent hole. This is messy but the truck still runs to get you home. In nearly 40 yrs. my '77 only had one fuel delivery problem and that was plugged main tank pickup filter, after filling it with cruddy gas.
kat
kat
Bristol
I have seen a MANY clear plastic inline gas filters on different types of vehicles and never know for one of them to cause problems unless they are clogged. But I understand them being a fire hazard. I was thinking of getting a smaller glass type inline filter but don't know it that will solve my problem. I do want to stay with the mechanical fuel pump because like you they tend to be more reliable.
When I bought the Bronco it had a big plastic fuel filter on it with a Holley carb, not a fan of Holley. I changed out the filter for a small glass type to catch more trash since I had just got the truck and didn't know what might be in the tank. And out of convenience when I put the Edelbrock on the engine, I used the bigger plastic filter that came with the carb. But if my memory serves me while I had the smaller filter on it, the thing stayed full of gas...but I could be wrong.
jckkys
My point was that a filter being clear offers no advantage. They were never used on new cars or trucks for good reason. Your problem was the result of misinterpreting what you saw, not an actual problem with fuel delivery. A metal filter won't confuse you with what you see. They simply do the job and don't break creating a fire hazard. I've used clear plastics simply because they're dirt cheap when I was too young to know better. After working as a fire fighter, I did. When a clear filter is plugged up with crud you still can't see it. It shows up in the way the engine runs, just like any other filter. A spare is easy enough to carry in the truck if you're concerned about the one in use, plugging up.
kat
kat
Bristol
I got ya....;)
What do you think about the skipping and sputtering when secondaries kick in....it doesn't do it every time, but when it does I have to back off do even go down the road. Understand this is a brand new Edelbrock..I haven't done any adjustments...by the end of the week I will probably take the top off and check float level.. Ive researched and said its a good chance they are not correct out of the box....
ntsqd
heratic car camper
Upper SoKA
I've never seen a car fire started by a plastic fuel filter. I have seen them fed by one after something else, usually a hose clamp that came loose, started the fire. Not saying it can't happen, just that in 40+ years of messing about with engines etc. that I've not seen it.
Once you know that the carb and ignition adjustments are dialed-in, then start looking at if you've got a fuel delivery problem. The OE fuel should have been able to keep up with most engines. As will a performance mechanical fuel pump. I've no such faith in current repair-replacement parts.
SHX669
How do you know the secondaries are kicking in ? The Experts say when tuned correctly you shouldn't know unless you've attached a clip or "tell tale " device to the secondary actuation arm.
jw0747
San Antonio, TX
If it runs fine x2 don't worry about what the gas in the filter is doing. From experience clear filters will drive you crazy just staring at them. Toss it in the trash and install a filter that you can't see what the gas inside is doing.
First thing I would do is check the fuel line running from the fuel pump to the gas tank/tanks make sure the hoses and lines are good and all the clamps are tight. I would also check the fuel selector valve in the foot well and make sure its not leaking. between the pump and the fuel tank these lines are under suction and if these lines are sucking air in you could have a fuel volume issue and air bubbles inside your plastic filter. There will always be some air seen in your filter but it should be mostly full of fuel. Allot of air in your filter your likely sucking air in.
After your assured that you have done the best you can from sucking air do a pump volume test. This is just disconnecting the fuel line at the carb and adding a length of hose and directing it into a container to a safe location where you wont create a dangerous fire condition. Crank the engine and catch the fuel and measure what is actually pumping. There is a minimum specification.
Next test is a fuel pressure test. Most good automotive vacuum gauges have this function. You should be able to borrow this gauge from the tool loan at the auto parts. Edelbrock probably has a spec their looking for in the manual for the carb. Usually in the 4-6 Psi range Too high a pressure is just as bad as too low a pressure.
Fuel pumps can work and still be bad. Most will leak under the diaphragm where there is a weep hole just for this failure. Another failure leaks fuel inside the pump lever hole in the timing cover and dumps fuel into your motor oil so pull the dipstick and see if it smells like fuel or the oil level is rising because of fuel coming in.
Once you verify that you have the proper amount of fuel coming in and pressure is within spec then you will have to chase tuning the carb.
Tuning the carb you want to verify that the truck timing is properly set and the plugs are good and there are no ignition misfires and no vacuum leaks.
hook up a tachometer so you know the proper RPM the engine is running and hook up a vacuum gauge so you can see that the vacuum gauge has a good steady reading usually at the highest vacuum reading you can get at Idle. Read the tuning manual that came with your new carb and follow through step be step.
If you love your Bronco don't run a Glass filter on the fuel line to the carb run it in a safe place away from heat in the suction line going into the fuel pump and not out of the pump. It still shows fuel flow and air intrusion the same information but a leak or failure is likely to suck air instead of spewing fuel under pressure on a hot engine.
kat
kat
Bristol
What I meant was when I kick the secondaries in (put the pedal to the medal) it will spit and sputter sometimes...not all the time.
Ok did some checking. I checked my fuel pressure and it is running a steady 6psi which is in the window according to Edelbrock. So I thought I would check my float levels, when I turn the top of the carb upside down and check the level it is at 7/16 of an inch as per Edelbrock. But when I checked the drop of the floats they were about a half inch off from what Edelbrock wants, so a adjusted them to where they need to be. I dont see the "drop" of the floats to be my problem unless they are drop to low and catching on the side of the carb inside. Do you think I need to check the jets while I have the top off?? Dont want to mess them up...Is it possible that I have a coil or something inside my MSD distributer that is getting hot after driving and not giving it the spark it needs??
bmc69
Is this a new problem? Edelbrock's, like most carbs, need some setup and adjustment to make 'em right. They are seldom right out of the box.
kat
kat
Bristol
Ive done what I know to do, I checked the floats, adjusted the air/gas mixture screws. But my biggest problem is not starting once motor is warm..got my timing tape in the mail and tomorroo going to pull #1 plug get TDC and time it. Which everything Ive read its anywhere between 12-16% BTDC..and change all the spark plugs...I dont think this is going to solve my issue but its the next step. Once the motor is warm and I turn it off, I can try to start the engine and it cranks very quick, but the longer it sits the harder it is to start..until its the engine is cold again. The engine is not overheating BTW...Ive read the owners manual for the carb/watched the DVD that came with it but other than replacing jets there is nothing else for me to do (that I know of).
SHX669
Without rereading all of the posts and isn't there another previous post about this? - timing too far advanced can cause hard starting when warm.
You say you have an aux tank but it's not hooked up ? If so does the fuel line from the main tank still go to the selector valve? If so bypass it completely. I've seen a couple of those 3 way valves leak either thru the "open port" or the packing gland on the selector shaft.
When warm can you turn the key to start for 5 seconds or so then pump the gas once and then see if it'll start? If it does this then it's fuel evaporating/boiling from the carb - common now with the stuff they call gas.
Do you have electronic ignition ? When the magnetic pickup is going bad it can start cold , run fine warm but once you shut it off won't start till it cools off - had that issue last summer - got to do a 5 mile hike that day but it happened to be beautiful weather day.
jckkys
Now that we know you have an AFB, aka Edelbrock Performer, the problem can be diagnosed far easier. AFBs open the secondaries mechanically when the throttle is fully opened. A counter weighted air valve over the secondaries opens as the engine pulls more air. It sounds like an accelerator pump adjustment is needed. Edelbrock has a great owners manual available as a PDF that walks you through the set up process. The amount of fuel per throttle opening stroke and at least 3 different sizes of nozzles determine how much and how fast the fuel is delivered. Once you've done the set up, the stumble should be cured.
kat
kat
Bristol
Yes I have a different thread about my timing..I thought I wasn't getting the proper gas...which now I believe is not the case...going to a buddies this morning that has more knowledge than me, wer're going to put it in time by finding TDC and go from there...I do have a electronic ignition and yes that pickup has been on my mind of maybe the problem....Ive double checked all my lines under the Bronco and find no leaks or pinched lines,,,
