Not starting after head gasket replacement
sigepkat
Headline says it all...After replacing the head gaskets on my 302 (EFI), my truck won't start. All I'm getting is backfiring...My guess is I installed the distributor wrong, but before I pull it and try again, does that sound like an accurate guess? Could it be something else?
CM
68stang73
Sounds about right. But then did you adjust the valves properly? Not sure on the efi motors. But ya get it to TDC then look at the rotor to see if it's pointing to #1 cylinder.
JAFO
Beaverdam
Backfiring sounds like timing. Might be 180 out of time. When I install a distributor I turn the motor over by hand (spark plugs removed) until #1 piston at TDC. I usually put a wooden dowel in the spark plug hole to feel and verify piston is a top dead center (per timing mark). Then I have the valve cover off and verify that both valves are closed. Dizzy rotor pointing at #1 spark plug when dizzy is in place. That should be firing position for all the moving parts.
Rustytruck
If the distributor is in right. putting the No. 1 cylinder on compression (passengers side piston closest to the front of the truck) and the harmonic balancer on TDC the rotor under the distributor cap should be point back towards the firewall. Start the plug wiring at the cap from there going counter clockwise. Your EFI motor uses a different firing order than the stock Bronco.
