EFI,(my head is spinning, its starting to slow down.)
HoosierDaddy
englewoodcowboy
Lick Creek Restorations
If you havent bought anything yet, go to you tube and seach powerjection 3. Watch the install on the mustang. Neat system and reasonable price of sorts. It was what I was going to go with but I wanted a roller motor and serp belt sys so I bought a complete car and am going to do the RJM wire harness and use the factory EFI... JMO
kc15842
Lake Elsinore, Ca
Good post, look thru some of the pics to see the fit to the compartment. My lesson learned is the c4 isn't much on the freeway. The trans option with an of is a nice option.if you like the pics of my 5.0 HO, all 91 mustang GT including the AOD, I'll offer my parts list and experiences. One concern is $$ and time, you won't find all the answers in one easy location
stupidboy
stupidboy
My wifes porn star.
Morrisdale Pa.
Looked at your gallery, very nice!;)
NYLES
Lil info I decided to try and go ahead with my current flat tap cam to avoid the 700$ worth of roller stuff to make it a roller again. Will post results when its done. btw this a 302 firing order and the biggest cam I can run with a C4 and stock converter.
You plannin' to run it as-is, or are you going to have the ECU tuned?
stupidboy
stupidboy
My wifes porn star.
Morrisdale Pa.
Let me ask this. I'm getting ready to buy the rest of my efi stuff for my swap and I want to make sure I get the right parts. Its been a while since we talked about this so I've been searching this stuff on here again and can't seem to find the answer, so I need refreshed. I am using a 351 which has the HO firing order. What computer is the best to use? Does it need to be from a 5 liter HO? I thought I read somewhere where the computer will run both firing orders but will have rough idle and maybe other issues. I don't want these issues. What computer do I need to run my 351 firing order without issues for MAF? For some reason I have it in my mind that the computer will be firing the wrong injectors or is this wrong?
Viperwolf1
electron whisperer
Any of the mustang '88-'93 ECU's will be fine with matching parts (MAF, injectors). http://rjminjectiontech.com/pages/50-compatibility-list
351W cam firing order is the same as the 5.0 HO cam firing order. Even if you use an older 302 cam with the 15426378 order it would be fine.
stupidboy
stupidboy
My wifes porn star.
Morrisdale Pa.
Are all 88-93 mustangs HO's? if not would the wrong injectors fire at the wrong time if I was to not have an HO ecu and harness? I think I found the answer, But out of the computers listed on the ford fuel inj. site, are they all HO computers? Just trying to have a better understanding, sorry.
Viperwolf1
electron whisperer
All these ECUs are mustang: A9L / A3M / A3M1 / S0Z / D3D1 / A9S / 8LD / A9P / C3W / C3W1 / A9M / A9T / 8LF / 8LG
All have the sequential HO, 13726548 firing order. Same as your 351W.
