np435 and a/c
NC-Fordguy
Bethel/Greenville NC
Guys
I have a np435/np205 combo that i'd like to install on a bronco with a one inch body lift. Been reading the threads and that seems doable. I would like to add an under dash a/c unit from vintage air, toms, etc..will this work??
My memory of the 435 and underdash clearance (like the shifter self clearancing the heater vent the first shift into granny) tells me there is precious little real estate under that dash. Unless someone steps up and counters me, I will say there is not room. 1" isn't going to gain enough room.
But if someone can say that it does work, I will be amazed. But I think it will take more then an inch of body lift.
Now if you are looking at an in-dash A/C system and not the simple under dash vents, I am sure that will be workable. But that will be a much more involved install. that is why the under dash systems are used, they just drop in so much easier. Unless you have a shifter in the way.
Dan74Bronc
Chandler, Az
Worked for me.
Dan74Bronc
Chandler, Az
After reading Tim's reply I must confess it wasn't a "sure fit". I didn't use any of the made to fit bronco stuff out there. I used the largest evap Vintage Air had and made it fit. I had to move some sheetmetal here and there though.
blubuckaroo
Grease Monkey
Ridgefield WA
The Vintage Air with the under dash registers should work. The practical advantage of those over the in dash registers is that you can put the register where it will do the most good rather than where the dash arrangement dictates. They can be installed anywhere along the bottom of the dash. That thing is insulated like the space shuttle!
Madgyver
Bronco Madman
Dan,
I love that a/c install in your rig and all the metal work you did to make it fit.
Would you share the part # of the vintage air unit that you used?
Please post more pics and pics of the routing of the hoses (heater and pressure hoses) from the unit going through the firewall.
madgyver
Dan74Bronc
Chandler, Az
Mad, the unit is the 61005 series GEN II Super Cooler, the large one for big sedans (24" wide).
what sort of insulation is that?
Mongo, The insulation is 1/4" closed cell foam with aluminum backing on both sides. I got the insulation from www.lobucrod.com
Here are a few more pics for your viewing pleasure.
Dan74Bronc
Chandler, Az
And a few more.
NC-Fordguy
NC-Fordguy
You all think a gear banger from wild horses would solve the underdash issues???
Mad...you da Man. Enjoyed reading that thread
Dan...that looks awesome!!!!
Thanks for the ideas!!!!
Dan74Bronc
Chandler, Az
Dan - Do you have a body lift?
I had no body lift for years while running the NP 435. Installed A/C 2 years ago and just this year I installed a 1" body lift because my rear tires rubbed when stuffed.
blazinchuck
Ed, im in the middle of installing the 435/205 right now..but im not using a body lift. its kicking my butt...as for the gear banger, it will be close to the dash. i know they make the shifter per your body lift. I had to remove mine cuz it made a bad shifting tranny much harder to shift. im wishing i had atleast 1"BL now...lol
