Np435
KAllen
Talking Rock
Thinking of swapping in an np435 trans and a np205 case
Just curious if anyone has done this so I can get some pointers
AxlesUp
Collierville TN
i have not done it but my bronco has that setup in it :)
the gearing is amazing, but it is a bit of a chore to shift.
my tunnel cover was raised for sure and i have a massive flat belly skid plate that everything seems to attach too.
mortimersnerd
I've got an np435 and Dana 20. I like it, but am glad to have the lower gears of the d20. What axle gears and tire size are you running? You'll lose gearing with the 205.
The 435 and D20 combo is nice as you can keep the transfer case in the stock location and use the stock driveshafts. Use the original crossmember in the original location.
While the 205 is stupid strong, the gearing isn't as good. What you save by not getting an adaptor for the D20 you are probably going to spend on the transfer case, correct yokes, and reworking the driveshafts to fit.
Using the 435 and D20 there is little more than poking a (big) hole in the floor for the shifter. 435/205 is suddenly a lot more work and a bunch of little nickel and dime expenses. I know of a lot of 435 conversions, I can't think of any that used the 205.
KAllen
KAllen
Talking Rock
np 435
gears will be stock 3:50
tire size will be no bigger than 33
any pictures of this install would be great
Pa PITT
Stephenville TEXAS
Pictures of 33's on bronco
.. Here's mine .....
...1st is my Bronc up on 33 ..
...2nd is the NP435 shifter showing & along with the twin sticks. Also notice the Hand Throttle on the shifter handle
..3rd is just another picture of my Bronco with 33's loaded with the Np435 .
... I didn't have to make any adjustments to the drive shafts. Other than swapping the yokes from front to back.
AxlesUp
Collierville TN
a few pics.
once i get the steering back on its off to the pressure washer!
LOVNBRONCOS
Tucson, Az
Here's a few pictures, Wild horse gear banger makes it shift great.
Tedster100
Chairman of the Bored
I ran this, exact setup & loved it. 435/205 3.50 gears 33" tires. Granny gear in NP435 is great & unless you're doing a lot of serious crawling the gearing is pretty good. I made a custom cross member, tunnel cover and gear banger for it. Had to switch when I swapped axles, the axles I picked up had 4.10's and lockers so I couldn't go back to 3.50's and the gearing was not suitable for the highway with the higher axle gears so I swapped a ZF in. I've actually got the whole 435/205 set up sitting on a shelf if anyone's interested.
AxlesUp
Collierville TN
what did you change to swap in the ZF and what did you use for a t-case?
i really thought i had the sole crazy shifter lol honestly it works rather well.
let me know if you need any more pics.
Tedster100
Going from the 435 to ZF isn't that bad but it's not that easy either. Notch the ZF to clear the shift rail, I used JB Fab twin sticks. Cut the tunnel, get rid of clutch linkage, install ZF master cyl, I used BC Broncos ZF cross member and made a support for the NP205 myself, modify driveshafts, bolt it up. There's a lot of little details but if you do the prep and line all the parts up it can be done in a weekend.
