Where are the really short shaft “2wd” NP435’s actually 4-wheel Drive models from divorced transfer case F250’s perhaps?
Official thread jack warning!
@Broncobowsher said: "But the 2WD had a really stubby fixed output yoke."
Are you two talking about the same thing here?
There are several "short" NP435 output shafts. And I am no expert. But I know enough to keep me out of trouble. The back of the Ford 4 speed dates back to the late 50's and the T98 in the medium duty truck. In the 60's the T98 was upgraded to the T18, and was introduced to the pickup. In the Medium Duty, the output shaft had an integrated parking brake, and a fixed yoke and no rear cross member. The bell housing was the rear engine mount. But by the time the late 60's rolled around, the NP435 was configured to use the 28 spline "pickup truck" output with the "foot."
Anyway, regarding NP435 output shafts, it starts with the case, and the output bearing, and then the output shaft. The output shaft either has a speedometer provision, or it doesn't. The "really short shaft" 435 has no speedo provision. It just goes bearing, snap ring, to splines. But I don't know what if anything they were every used in. They could have been used with the divorced Dana 24 transfer case since the speedo on the Dana 24 is on the output of the 24. I do not believe that the "super short" 435 was used in a pickup truck, because there wouldn't be any way to support the back of the transmission. See the first picture below.
In the F100 with the Dana 21, it used a single speed transfer case, and was married. It also used the 2WD square pattern case. So it is a 4x4 that uses the 4x2 transmission, and an oddball C6TZ-7024-B spud shaft. But they kept the speedo on the transmission output. Later on, like in 73, the 435 got married to the 31 spline input NP203's and then in 77 it got married to the 205. Those outputs are "long"
I don't care what you call them, but it gets confusing when you call things "short" and "long" when there's "short-short" and "medium-short" and "long-short" depending on whether you cut off the threaded part. So they can be 4-1/4 long, or 5-3/8 long. But at the end of the day it doesn't matter what you call them. You usually end up using what you have. The VAST majority are 2WD pickup transmissions with 28 splines, and speedometer provisions and threaded yokes. The 4WD cases that were married to NP203's and 205's had the trapezoid pattern which has become known as the "4WD" pattern. (even though the Dana 21 doesn't use it..."
While I'm here, I will point out that Advance Adapters also makes a "short" 23 spline output for the NP435 that sticks out about 4 inches. Novak also makes a short 23 spline output that is an inch shorter than Advance. If you are building a CJ, or wanting a doubler...those are as short as you can get without buying an SM420. They also use a snap ring for retaining the rear bearing. Note that the Chevy version also has its own short-short output shaft.
Here are some pics to help out:
