If the transfer case is the NP241OR...it will also not fit between the frame rails. But it does come with a fixed yokes, 6 pinion planetary, and 4:1 gears.
And then you have to figure out the speedometer. NV3550 + NP231J, or NP241OR will be a tone ring with a magnetic pickup.
you can run a clocking ring and rotate the t-case down...but that makes it vulnerable to the rocks. Or you can notch the frame. Or you can shift the drivetrain to the right another 3/4 inch.
Or you can buy the adapter for the Dana 20...which is where most everybody else ends up.
