tj
Background: 1970 302 engine loosing Duraspark ignition, & 4 barrel carb which is being replaced by a 1993 Mustang EFI system.
Next on my to-do list is to fabricate an O2 subharness that goes between the '93 main harness and the sensor connectors. I have no problem matching up the wires coming from the computer connector but the wires from the O2 sensors are confusing.
QUESTION: The O2 sensor has 3 wires, one black and 2 white. One should be ground, one 12V for the heater and one the sensor output. The plug has the connectors arranged in an "L" shape. I'm assuming the black wire is ground. HOW do I tell which white wire is 12V for the heater and which is the sensor return???
BONUS QUESTION: I am using a transfer case behind my T-18 that is incompatible with the Ford rev sensor unit. How big of a problem am I looking at not having the RPM sensor?
TJ
TJ
