Let me first state that this thread is simply an observation of the Wild Child lift off hinges that I received from the mass buy, and is no way a bashing of a product.
Like most of us, there is no way I can justify spenting $400 on the stainless steel lift off hinges that Wild Horses sells. I have seen them in their show room, and even though they are very well made, they are't worth $400 to me. I got in on the recent mass buy on the Wild Child hinges, and was pretty much expecting a mild steel version of the Wild Horses hinges. I was quite surprised at the hinges when I received them, and now understand why they are so much cheaper than the Wild Horses hinges. The Wild Horses hinges are two single cast pieces whereas the Wild Child hinges are simply two pieces of steel bent and welded to emulate the stock Bronco hinges. Instead of being cast in the final configuration, the door side of the hinge appears that it is simply bent in a sheet metal brake to get the right curve to it. Then, the two pieces that make up the lift off portion of the hinge are simply welded on and ground smooth on the back side. I actually had to grind some weld spatter off of three of the four hinges to get them to fit together correctly.
I offer this observation as a heads up to others who may be considering buying the lift off hinges from Wild Child. I would not say that I am dissapointed in the product as I am sure that they will hold up for many years, but I was quite suprised upon unwrapping them from their shipping material.
