Ok, thanks guys. Sounds like I have a project for this Sat. AM. As, I said, the bolts I pulled out were threaded from head to tip, no shank or shoulder, so whoever did the last clutch just grabbed bolts out of an old parts bin or something. Glad I started this thread, as I had a set of 6 shiny new grade 8s with no shank or shoulder to replace them. I'm sure it would have been fine for quite awhile, but that would have been a crappy reason to have to pull the tranny and clutch down the road.
The other thing, as it turns out...I'm replacing the flywheel (50 oz) from Tom's and the pressure plate (LUK). The bolt holes that line up for the pressure plate are a larger diameter (fatter) than on the stock flywheel. Will I find "Ford" pressure plate bolts in this diameter, or will they only come in the factory specs?
