odd spindle lock nut
tpatton75
Anybody come across this kind of lock had Warner hubs?
bronconut73
I think mine look like that.
I believe that is just the regular spindle lock nut, right?
T
tpatton75
First nut is normal special lock washer outer nut has Allen set screws and was finger tight
Steve83
The only purpose for that system would be to make VERY fine adjustments to the wheel bearing preload; much finer than these trucks (or any other I can think of) would need.
It would also eliminate the need for the special spanner wrench to torque the outer nut. But that's just a side-effect (and not really a good one).
langester
MASTER OF MADNESS
I had a Scout II in High school. Those look similar to the ones it had. It had automatic hubs and the outside lock rings had allen screws in them also. Been a long time ago but sure does look familiar.
I think that's getting warmer. I was thinking automatic as well, though I've never actually worked on a set, so can't be sure.
What does the knob and mechanism look like tpatton? Does it look just like a normal one, or could it say "auto" on it somewhere?
sprdv1
REBEL
all looks standard cept for the top washer/lock cap, not seen that one
ntsqd
heratic car camper
Upper SoKA
I believe what we're seeing is the system used by Warn on, at least, their GM application locking hubs but with a PO mod of the drilled and tapped holes and the set screws.
Superwinch used a similar locking method behind their locking hubs. My '79 Sub had the same set-up, minus the set screws, under it's locking hubs. I've threatened to drill & tap yota wheel bearing nuts to do exactly that.
Apogee
Tangent, OR
There are several similar aftermarket options like that for the Toyota crowd...works fine.
gddyap
Mtn View, CA
Ford used a self locking nut with the auto locking hubs. It had a spring-loaded ratcheting locking feature. You tightened them enough to preload the bearings and that was it. They worked with some Superwinch hubs I had but didn't fit under Warns. I don't know if they fit under stock locking hubs. They look like this:
Justafordguy
I've seen them before on one of my Broncos in the past. I don't like em, way more trouble than the standard ones. I would replace them with the regular lock nuts available through our vendors.
SpareParts
The came factory on my 1988 bronco... it had the weird lockouts like a Ranger or a Explorer had. When you remove the wheel, the lock out would set overtop of the studs and would slide off. I've only seen one other one like it.... Mine was a Custom, no power anything, 302 and C6.
SpareParts
Not the type in post #1 of this thread. Maybe the type in post #12 . %)
Yeah, your right... I'm using Tapatalk on my phone to look at CB.com. It shows the last pic in the feed. I'm guilty for not reading the whole thread.
