- Joined
- Mar 8, 2007
- Messages
- 81,985
Suspension has been installed.
Original Master cylinder and brake lines have been removed.
New Brake system is next with rebuilt Disc up front and added Disc on the rear.
getting closer brother....
The entire Drivetrain has been pulled. I will install a nice 351W with the AX-15 behind it.
If anybody needs a decent running 302, come and get it. It's yours.
Since I will not be fully restoring this Bronco, I completely stripped the engine compartment and painted it Black. I am usually Not a fan of this, but it turned out OK.
New Steering Box and Lower Shaft, Power Brake System and other Engine Compartment items will be installed next.
Previously, (Previous Owner Option) the Radiator Brackets were moved down to match the 3" body Lift. I will install a 2" Body Lift and move the Radiator Mounts back to the stock location and have a proper Fan Shroud for the Body Lift.
The list keeps getting longer But I should be back up and running within about a month. Wish me luck....
The Front End Caster on this truck turned out very nice.
I have a 2 1/2" Lift, T-Rex Arms and 4* Bushings. Alignment came up with +4.4, and +4.6.
I have not gotten the truck up to highway speed yet, but up to 45mph it's Very nice to drive. (Loud with No exhaust)
I have most of the engine complete. I still have to install the Air Intake hose and also block off the Air Cleaner where the second Snorkel was.
I have a temporary right side exhaust tube installed with the O2 Sensor to get it started and tuned. A Full 2-into-1 exhaust will be installed next week.
I drove it around a little yesterday and today. Very torquey motor and sounds very smooth even with the lack of exhaust.
Progress.
Gnsteam - These trucks do like Caster. Did the shop say it was too much Caster? How does it drive?
The Air Cleaner is very similar to the Mustang GT 5.0 Air Cleaner. I'll block off the second snorkel and install an air tube to the original Cold Air Intake.
I like the look. Kinda old school. Kinda unique.
