hboutlaw
After replacing the mechanical fuel pump we've developed a pretty serious oil leak. This is on a 71 302 stroked to 347. At first I thought it was the new fuel pump but when I put another fuel pump but noticed when tightening the bolt towards the front of the engine that the threads had been stripped...bummer. Shining a flashlight up to inspect the fuel pump mounts I can see leak was still there but what's worse is it appears a small piece of the block where the bolt screws into may have failed and chipped off. There is a much longer story behind the replacement of the fuel pump that I won't bore you with...has to do with my son deciding to do the work when I was traveling.
Questions:
How do you fix this?
Can I cap it and use an electric fuel pump or regardless of using a cap or pump I'm still faced with a significant task of welding the block?
If the electric fuel pump is an option, which fuel pump is recommended and where should it be placed for best performance?
That's a long story with a lot of questions but I'm faced with some big dilemma right now.
Questions:
