Oil leak (Mystery)
DeepC73
I installed a rebuilt 302 about 18 months ago. Back in October I noticed a slight knocking and immediately checked the oil and it was about a 1/2 quart low. I refilled it and looked for a leak. I found a slight leak under both valve covers (very small). I also found a light amount on the oil filter and on the oil sensor adapter extension. I repaired the valve covers, but I can’t find where the leak is near the filter and the sensor extension. It’s enough that it leaves a light film on the frame on the driver side. It never drops or leaves a puddle. I’m going through about 1/3 of a quart a month or so. I drive it everyday. I have 40 psi oil pressure. It’s killing me that I can’t find it. Any ideas are welcome and much appreciated.
ba123
CA
Any idea on the build quality? Who built it?
I’d guess you’re burning some. 1/3 qt of oil per month is a lot, imho. How do the plugs look?
ared77
Maybe try dye and UV light?
DeepC73
DeepC73
It’s probably closer to 1/3 qt every 4-6 weeks. Either way, too much. I have been thinking about the UV dye idea. I haven’t pulled the plugs recently. I’m about to hear in about a half hour after I’m done with my nightly duties. I will post pics in a short while.
Slowleak
Georgia
Check the fuel pump. There is a seal inside of it that can go bad and allow oil to blow out of the weep hole. There are several threads on here about it. It will blow an oil mist onto the filter and pressure sensor.
DeepC73
DeepC73
Slow leak, I am familiar with the oil pump seal. I went through 3 of them on my old engine prior to replacing it. I don’t think that is it, but it does merit a look, thanks.
I just pulled all of the plugs and have provided links below. It looks like it’s running a bit lean IMO.
Cylinder 5 https://share.icloud.com/photos/081ZZh-OD2EdiTuNnEYW7jPiQ
Cylinder 6 https://share.icloud.com/photos/0a3KVblTbmfycYqxViFt9_OxQ
Cylinder 7 https://share.icloud.com/photos/02eaE6jBSCdW17Cuy2kKYNOyQ
Cylinder 8 https://share.icloud.com/photos/0df0YHMLubdC3L6-1uiH8AnPA
Cylinder 1 https://share.icloud.com/photos/05dF6-mPAkLyMItIn4e5ohU6Q
Cylinder 2 https://share.icloud.com/photos/073n279lJ19WSBlpee2fkXO7w
Cylinder 3 https://share.icloud.com/photos/019i7DMqb-Fy-uD3P7e6y5clQ
Cylinder 4 https://share.icloud.com/photos/010J_U0n6xCcMtNRFEt_5L6pA
ba123
CA
My spark plug analysis is def rusty but that looks like burning oil to me.
Since the plugs are out (hopefully still) how about compression checking the cylinders?
m_m70
Prescott AZ
I would agree that they look a bit on the lean side. Maybe burning some coolant.....
Slowleak was talking about the fuel pump, not the oil pump.
Was that just a typo on your part? Or were you referring to the internal oil pump?
And just FYI, that 1/2 qt low did not cause any knocking.
If you’re running a stock 6 quart pan and pickup, you can run it almost 5 quarts low and still have full oil pressure. At least on the street under mild use.
I’ve actually experienced that before, with no effects.
Just so we have a point of reference that most of us use, how many miles are you getting before you’re a quart low? I know you said you drive it every day, but how many miles is that?
You may have to remove the oil pressure sensor extension and seal the threads better.
But also, you might have to inspect for cracks.
They are notorious for breaking off where the threaded part meets the hex part.
I almost hate to tell you to remove it, unless you have a new one at hand. Sometimes just unscrewing it will break it off.
Not one of Ford’s better ideas, using aluminum for the extension. Maybe you’re lucky and already have a steel one?
ba123
CA
:eek:
Yeah, I was thinking similarly about the knocking...but that low is LOW. Reminds me of the car that was supposed to be my first car. My mom's old car, my sister got it first and NEVER ONCE ADDED OIL.
That changed directions for me and my first car was all I could afford: a motorcycle.
My first was a motorcycle too!, Then a snazzy convertible, then the bronco.
When I bought the bronco, during the first test drive (multiple test drives were an option back then before the fever hit) I noticed that the pressure was 75 psi. That was more than I was used to seeing on Broncos, so I was pleasantly surprised.
During the second test drive, it was the same way. Engine ran a little poorly, but that was unrelated.
When I went back the third time and purchased it, the owner checked the oil for me before we left the driveway. Didn’t even register on the dipstick!
Put a quart in, still didn’t register. Put another 2 quarts, same!
The fourth quart got it about a third of the way to full on the dipstick. Got home that way and started the long road to reducing oil consumption with my new bronco.
But no funny engine noises at that point.
DeepC73
DeepC73
Thanks everyone for all of the ideas and suggestions. Paul, yes, I did mean to say fuel pump. Unfortunately, a compression check is not possible. My neighbor borrowed my tester and is out of town for a week or so. I have been through 3-4 fuel pumps in 3 years. Each one starts blowing oil out of the weep hole. After really cleaning things off with degreaser and brake clean, I discovered it’s the fuel pump…again. I put a new (rebuilt) engine in July 2022. I haven’t had to change it since then. I have been getting them from Napa and Auto Zone. I guess I’m going to have to get a better quality pump. Any suggestions? What would cause them to keep failing? I don’t think I have excessive crank case pressure. While looking around I made an alarming discovery. I found what I thought was the smoking gun; a hole in my oil pan, pic in link below. It’s facing the fuel pump and oil filter, which is where the problem area is. As crazy as it is, it doesn’t appear to be leaking. I have no idea how it happened. The oil pan was new when I put the engine in. As I said, it turned out to be the fuel pump weep hole. I will replace it…again.
https://share.icloud.com/photos/03djCzPcOdyvKk_5bxenIPLhQ
ba123
CA
hate to say it, but that looks like it was caused from the inside.
If it were me, I'd inspect is as closely as possible, drain the oil and look for metal, and prob drop the pan but I'd also want to be sure of where the leak is first and run that compression check as well so that if you do need to pull the motor, you only do it once!
m_m70
Prescott AZ
Soooooo did the knock go away when you topped off the oil?? Having a knock with only being a half quart low and 40lbs pressure would concern me more than anything at this point.
DeepC73
DeepC73
The knock always goes away when I top it off; for a little while. It really sounds like a lifter tick more and more. Tomorrow I will be dropping the pan to see what’s going on down there. I agree with ba123, it looks like it came from inside. I’m trying to think what is in that corner that would have caused it. I know the oil pump is in the front, but it doesn’t make since. I will inspect the inside to see if it goes all the way through. If it does I will weld it up. I’m still scratching my head on what internally could have caused it.
ba123
CA
A rod/bolt is the only thing that would cause that is my guess but would be odd if it still runs. Anything’s possible but unlikely.
m_m70
Prescott AZ
yeah I agree with this ^^^. Other than a knock/tick does the motor run OK?? guessing it runs good if you're driving it daily.
I went with an Edelbrock fuel pump. Think it was the 1725 from Summit. Expensive (for a mech fuel pump) but I've had no issues in 12 years or so.
On a side note, I run the reusable oil pan gasket. Works great and I have had no leaks in half a dozen or so removals.
DeepC73
DeepC73
It runs great, other than the light tick. I’ve put 8k miles on it in the last 18 months. I do indeed drive it every day. I also use the reusable gaskets and love them. I’m very curious about what I’m going to find when I get in there.
