been getting an oil leak at the front of the engine for as long as I've had the Bronco. I always thought it was the intake gasket. But, today, I started the engine and held the throttle open for a while and high rpm and watched the front of the engine. At the higher rpm, I saw oil accumulate at the top of the time cover. I wiped it away and it immediately came back. As best as I can tell, it's coming from between the engine and the timing cover, not down from the intake manifold area. Is this possible? Is there oil inside the timing cover at pressure? Leak increased with engine rpm. I think that's why I never saw it before, I normally just idle the engine.
