Fan comes off, accessories come off, water pump comes off, harmonic balancer comes off, loosen 4 bolts from the oil pan to the bottom of the timing cover. Snap bolts running through timing cover by cooling jackets %)
It's not terribly hard but definitely time consuming. Basically the front of your motor comes off until it looks like this
Then you pull the cover and you're here
Then your OCD kicks in (if you're like me) and you figure you might as well replace the chain.
Then you're rebuilding your engine. :-X j/k In all seriousness it's not terrible but a lot of work.
