Oil pan removal question
tbruz
100% bone stock 1976 Bronco with 302 and c4 auto transmission and stock exhaust system (Y-pipe). Also stock height, no lift.
Just had my garage floor coated and I've decided to clean up the leaks.
I'm attempting to stop the oil leaks from the flange on the oil pan that the dipstick goes into.
My question is this: Can I drop the oil pan on this rig without having to remove exhaust, starter, lift engine, etc., etc...
Will probably replace the rear main seal while I'm in there IF I actually go in.
Thanks in advance.
Tbruz
serial car restorer
Yes, I'll restore almost anything...
Western Oregon
Having just completed this work on mine, I'm going to say that dropping the pan completely on a no-lift Bronco is going to be tough, maybe impossible. You might be able to horse it out if you put the frame on jack stands and let the front axle hang. Maybe disconnect the shocks, springs and track bar so the axle will hang as low as possible. Lifting the engine would help also, but that's a pain.
Shouldn't need to drop the exhaust, I don't think the Y-pipe will be in the way. (I have stock manifolds on mine, but duals.) Starter doesn't need to come out, but it is easier to get to the pan bolts on that side if you pull it. (It's only the big wire and 2 bolts.)
FWIW - mine has about 3" suspension lift, I dropped the pan with the Bronco sitting on the ground. Still had to horse and bump the pan around a bit to get it out and back in. So on a no-lift rig I'm going to say you want at least 3" more clearance between the pan and the axle than you have now with it sitting on the ground. If you can't get 3" with the frame on jack stands and the axle hanging loose, you aren't going to get there.
T
tbruz
scr- Thanks for the real life input. You may be onto something with regards to the letting the front axle sag.
I just got a peek at the FORD shop manual from 1976 and the oil pan removal process only has three steps listed:
1- remove air cleaner and air duct
2- remove oil dipstick tube nut on the exhaust manifold
3- remove oil pan bolts to remove oil pan
I assume this "simplicity" is due to the vehicle being up on a lift with the front axle sagging due to gravity and/or being able to have sufficient clearance to not worry about the pan hitting the ground as you rotate it out over the axle.
Tbruz
Shimmy
1977 Bronco
Maple Valley
I'm about to do this on my 77. is there a gasket on that oil dipstick flange that i need to buy?
@tbruz you could try putting big jacks on the frame in the front, remove the tires and letting the axle droop some to get more clearance?
That gasket wasn't designed to be a servicable item. The flange is riveted on. But that doesn't mean it can't be serviced. Need to remove the rivets to get it apart. Then get some sheet gasket material and make your own gasket. Most people will end up nut and bolting the flange back onto the pan with RTV to keep the oil from leaking through the bolt threads.
lars
Been here awhile
NorCal flatlands
Obtain a floor jack and some tall jack stands. Chock rear wheels.
Jack up Bronco under front axle. Remove front wheels. Extend stands as high as possible. Drop frame onto stands then let axle hang. There may be enough room at that point. If not, remove the coil springs and the axle will droop far enough that you can get the pan out. I just did that last week. I had a deep sump pan on my 408 so removing coils was not optional. Did not need to remove the starter. Can’t comment on exhaust, I have headers, not stock.
