,,,,, note >>> they can't be used with the stock ribbed oil pan rails ,but if you are running a smooth/flat rail oil pan definetly use them......the modern oil pans with smooth rails & the one piece gaskets are the way to go ,but they have no dipstick in the pan & require the use of a 83' & up 5.0 block with the hole in the block right above the drivers side oil pan rail for the dip stick.....some say the stock 5.0 mustang pans require a small lift ,but with my stocker height I used ford motorsport/racing oil pan kit part #M-6675-A50 ($88 from john bleakley ford a couple years ago) which is the 91-95 production 5.0 HO engine pan minus the low oil level sender port.... side note on oil pan gaskets>> the one piece gaskets are techinally for use only with the later smooth rail pans because the four corners where the pan turns down to the timing cover or the rear main caps is sharper than on the earlier four piece gasket pans....
