Oil pan spacers
collinbrewer
Austin
On my EFI 5.0 I have two 1/8" spacers that go between my oilpan and block.
What are they for and do I need them?
eds66bronco
Essex, Vermont
if they are what i think they are, they go under the pan bolts to help even the torque on the gasket. the ones i'm thinking of follow the contour of the pan lip along each side of the pan.
rcmbronc
Tomah WI
eds66bronco is right. They do not go between the pan and block. They go between the pan and the bolts. The pan is directly on the block surface.
That makes more sense...
Are they needed?
I won't go so far as to say they are needed. But I will say they are highly recomended. They are there to even out the clamp load holding the pan to the block. Keeps the pan from warping under the bolt heads. That helps keep the engine from leaking oil out the pan gasket.
If you have them, just go ahead and use them. If they are bent or missing, you could leave them off as long as you are gentle with the pan bolts. Don't want to warp the bolt holes on the pan or you will be chasing oil leaks.
76 bronco J
,,,,, note >>> they can't be used with the stock ribbed oil pan rails ,but if you are running a smooth/flat rail oil pan definetly use them......the modern oil pans with smooth rails & the one piece gaskets are the way to go ,but they have no dipstick in the pan & require the use of a 83' & up 5.0 block with the hole in the block right above the drivers side oil pan rail for the dip stick.....some say the stock 5.0 mustang pans require a small lift ,but with my stocker height I used ford motorsport/racing oil pan kit part #M-6675-A50 ($88 from john bleakley ford a couple years ago) which is the 91-95 production 5.0 HO engine pan minus the low oil level sender port.... side note on oil pan gaskets>> the one piece gaskets are techinally for use only with the later smooth rail pans because the four corners where the pan turns down to the timing cover or the rear main caps is sharper than on the earlier four piece gasket pans....
