- Nov 3, 2003
- 51,618
So just for another data point.
When the engine is off and you push on the pedal, is it solid, rock hard, and basically doesn’t move?
Then, when you turn the key with your foot still on the pedal, it goes to the floor immediately?
That’s what it sounds like, but I wanted to be sure.
Whether that’s the case or not, but especially if it is, I would recheck your booster rod to master cylinder piston distance.
This is the most common issue, as you have probably read here over the years, when adding new parts. And that’s true whether you add one new part to an old one, or both are new.
Short of getting that tool, just pull the master forward as the hoses/lines will allow, adjust the booster rod out, a quarter inch for example, then gently push the master back up against it.
If you feel the master piston touch down on the rod before the mounting flanges meet, then you know where you stand as far as rod depth.
Note that distance.
Pull it back apart, adjust the rod inward that amount, and push it up again. If the two surfaces meet before the rod touches the piston, lock it down and check your pedal action again.
In the modern age, there is every reason to suspect that you could easily have gotten two bad master cylinders in a row.
If this is just the first new master cylinder, it’s very possible that it’s bad right out of the box.
Note that distance.
