One Piece Door Window kit
ba123
CA
As I redo the windows again, and again, the more I learn and see now that at least this one part I was frustrated with is my own doing, but in my defense, the directions suck on a whole new level.
When I put the filler piece in, it should be more specific and say to roll the windrow halfway up, pull the channel to the window edge by putting your arm inside the door, and bolt it there. It should not say to simply put it in and parallel....or whatever crappy directions are there.
Window is back in, hole for channel modified some more, will put the inside sweep on tomorrow.
mustanggarage
I took some pictures. hopefully this is what you were asking for.
ba123
CA
Thanks for doing that. Nice to see it works so well!
I'll post a hopefully final and good one of mine in the next few days.
mustanggarage
the most important thing I figured out is to make sure you get the bottom stop set right because if you roll it down too far it will slip behind those sweeps and it is a PITA to get it back up without damaging them. but I am sure as many times as you have assembled and re assembled it you have figured that out lol
ba123
CA
The power window mechanism stops on its own right where the stop is and really doesn't even need the stop, but I do have them in there.
ba123
CA
I gotta clean up the glue remnants but that turned out perfectly. You'd never know that I did it 15 times.
The next one will be cake.
Really hope this helps someone.
If you want the felts, get the 10-205x for BOTH inner and outer. The one I got that is stickier rubber just grabs too much.
ba123
CA
Drivers side was a pain, but easier than all the effort put into the pass side!
DONE ✅
