One Wire Alternator Wire Harness
bannind
Ok,
I have a new beautiful 1 wire alternator and I am hoping someone can help me with the following.
I would like to totally remove the alternator harness at it's plug near the firewall/voltage regulator. Is there any way I can just remove that plug and then connect up the 3 wires to the needed connections. The plug I am talking about looks like a computer power plug and the colors of the wires look like green (smaller gauge wire) and a larger gauge black and yellow/black wire (colors might be faded and off though). I have a 3 plug weather pack connector I would like to replace the current prong with and then run the new wiring. Any help would be appreciated.
Thanks,
dan
Duke Nukem
Simi Valley
There's no reason why you can't ditch the stock connector since you won't be using all three wires anyway. Just snip off the old connector with wire cutters, splice the wires, attach the necessary terminal to each wire, and then assemble the weatherpack connector. Don't forget to use dielectric grease.
bannind
bannind
So I know this is a dumb follow up question - but which wire goes where? I have no clue since they all seem to go through the old voltage regulator for some reason.
dan
RRRAAAYYY2
Brantford, Ontario
You say you have a one wire alternator, that means only the main battery cable is hooked up, nothing to the regulator. If you need to hook up your regulator, then we will need to know what kind of alternator it is.
bannind
bannind
well it is the one wire alternator that you donated Ray - which I managed to win. I have the battery hooked via 4 gauge wiring to the post on the alternator. Can I totally remove the 'alternator' harness near the firewall and just leave the plug empty from the main harness? I am thinking I will need to do something with those 3 wires that go into the plug. I am guessing this because after I did totally remove that harness at the firewall I was getting no response from the bronco after hooking everything back up - no lights, no starter, no nothing. I know that the battery is good, because after hooking up the cabling, I am getting response from my ghetto power door locks, because they are on their own circuit. I am wondering if the alternator harness provides a ground back to the fuse box?.?.?
Thanks in advance,
dan
bannind
bannind
Anyone have any ideas? Throw me a bone here, I just need to hear her run for a few minutes to remind myself that there is a light somewhere in the tunnel - and that it isn't the train about to hit me..
Note to self - one project at a time. This 5 different projects tearing stuff apart, 'because I have it off anyways' is driving me crazy.
RRRAAAYYY2
Brantford, Ontario
how embarrassing, sorry I missed your user name. I think what has happened is the main power wire that originally went to the back of the alternator needs to either be reconnected to the alternator, or connected to the battery side of the fender wall solenoid. It supplies power to your main fuse box.
I am really sorry if I didn't expalin this to you before. It is something I am supposed to do.
bannind
bannind
Fuse Box to the Solenoid
then
Alternator directly to the battery
I will do that as soon as family finishes with dinner. Wife gets a little testy when I know what time dinner is at and I 'choose' (her words not mine) to be late.
bannind
bannind
That was it.. Hooked up one of the three wires and it started right up. Kinda surprising how quickly it started up after sitting for 45 days without running (hence the too many projects line in a previous post). Let her run for a few minutes and then checked the radiator (#3 of the 5 projects) everything looked good. So tomorrow I will do all the cleanup wiring and remove the unneeded wiring.
Thank you much,
dan
