jerrybromley
- Sep 17, 2018
- 344
So I had a leak in my transfer case that was coming from the front yoke and I pulled the yoke and seal retaining housing and replaced the seal.
Then I decided I would replace the rear yoke seal as well. I pulled the yoke and pulled the rear seal housing bolts ( as I did on the front ) And low and behold loose bearings started to fall
My question is what is the best way to reassemble this screw up ? Can you pack the bearings with grease to hold them in place or do I have to drop the transfer case and get it in another position ?:?
