- Mar 8, 2007
- 81,824
Some opinions are based on one or two applications/batteries. Others are based on 100's, 1000's, of batteries and applications.
Yes sir, Definitely..
Since I'm working on my truck & battery shopping I learn quite a bit and I think I know which way I'll go.
But, like everything else on a forum it's always apples to oranges
You will always have, "I like this' or 'I had good luck with this"
RRRAAAYYY, has some good points, hopefully we will get the answers to those questions, since they are to Optima Jim, I will let me take care that
Doing ' my homework ' I have many of the answers to those questions and the others I needed to make my choose
Why do you buy a battery are you buying the name or the performance of what it does. Are you buying it for the high CCA's vs the high Deep Cycle, the high CCA's vs the Recovery or the high Deep Cycle vs the Recovery Time. Most Battery's offer one or the other not both or all.
Doing some homework it seems AGM batteries do need a different or added help for recharing. Odyssey's work better with their brand charger. Just like RRRAAAYYY says OptimaJim tells you how to charge an Optima (fully - charge)
Is Optima a bad battery - No.
Does Optima use Virgin Lead - No
Is Optima made in the USA anymore - No
Is Optima as heavy as it was before - No
Do all AGM Batteries cost the same - No
If everybody is on the Sprial-Wound Gel-Cel wagon how come nobody talks about Exide ?
How come price was never brought up, does the one that cost more any better ?
Does the one that weighs more are better (way do the weigh more) ?
Does anyone remember Faradane ( the first Epoxy-Plate Gel-Cel Battery ) before the Optima came out ?
I can't believe I never tried that!
What do the Deka's cost? It might have been mentioned in one of the posts, but I don't remember seeing it.
Yeah, I wouldn't count on Optima Jim responding to any questions. He's posted 3 times in 2 years, all the same MO. " here is a bunch of info about why you guys don't know" and then he doesn't come back for several months.
Tom
Couple? They've been crap the last 5 years at least..
Prior to 2003 Optima was THEE name in offroad batteries.
But then their manufacturing process changed. They were bought out and mass sold in multiple discount stores, they weren't as good. One of my yellow tops from 2003 is still going strong. My other yellow top from 2003 failed and I purchased the Deka Intimidator which was recommended by many on this site.
Picked up the new Deka Intimidator 9A78DT from the local Owens Auto Supply for $149.00.
What model number is it ?
There website says Group 35 (8020-164) weighs 31.7 lbs.
