Overheating-cured
NC-Fordguy
Bethel/Greenville NC
I've posted up in the past, looking for suggestions to cure an overheating problem that has plagued my trail rig for years. The over heating problem would occur running around in low range trail riding.
I wheeled this past weekend at uwharrie national forest in North Carolina where outside temps were 100 degrees and above. The hottest the bronco got was 190 degrees with me hammering on it.
The specs on my rig is a mildly built 302, c-4 tranny, 4.56 gears, terra low gears for the t-case, Holley TA carb, msd ignition pushing 37x12.50x15 tires.
Over the years I've swapped out and changed parts to try to cure this issue with lots of frustration as this problem would only occur off-road in low range trail riding
Here's the combination of parts that performed well this past weekend. Perhaps this might help some one else who has been experiencing similar issues.
BC Broncos triple pass radiator
12 in electric pusher fan(would have liked to try a larger size but space restrictions limited it to this size)
160 degree thermostat(robert shaw brand)
flow kooler water pump
long tube ceramic coated headers (hedman brand from Toms Bronco parts)
BC broncos water pump pulley
Fixed blade fan
bottle of water wetter
50/50 mix water anti-freeze (Shell brand)
Rox Crusher
yea, but what kind of filler did you use to fill the radiator ?
;D
Seriously now, how much do you think the water wetter stuff helps ?
And did you make all those changes at one time, or have you run some of them on the trail before? Just checking to see if any of them by themselves did not help.
Seems like you've got all the bases covered though. Except maybe for aerodynamic air-flow, but that wouldn't help much at such low speeds anyway. And any lack there, would be helped by the electric fan at trail speeds.
Wonder how much a part the fan played? Seems like it would be a big help.
thanks for posting up. Keep the updates coming if you see any differences under other circumstances.
barronj
I'm the anomaly. I put in a 351, and had to switch from a 180* thermostat to a 190 just so I would do a proper "break-in" on the motor. With the 190, it runs 190 (mechanical gauge). This is in Texas, no less. Hotter than a match head.
Congrats on your cooling issues.
My first Mustang would run hot, and I would always lose races to a buddy by a car, car & a half. I eventually switched to a lower thermostat, and beat him handily every time after that. He refused to believe that all I'd done was change thermostats, but it was the truth.
NC-Fordguy
NC-Fordguy
The parts have been added over the years. Each part I changed out or added helped but eventually I'd end up pulling off the trail and open the hood to let the bronco cool down, cycle it once or twice before continuing the trail ride.
The last parts I changed was the water pump pulley and fixed blade fan. This seems to have finally been the deal maker.
The 160 degree thermostat helped as it would buy more riding time before I'd see ugly tempatures. The 180 and 195 degree thermostats just seemed to aggrevate the situation
The ceramic coated headers replaced some rusted out steel ones. The thought there was to reduce engine bay temps. I'd pop open the hood with the steelies and would get a rush of hot air--kinda like opening a pizza oven. Could barely touch the hood prop sometimes.
Water wetter seems to knock down the temps just a little. I had used the stuff back in my racing days where the race car doesn't even have a fan. Seemed to help back then, but those engines were turning 6k plus rpms.
I think the electic pusher fan helps, wish I could have fit a larger one as it only covers perhaps a third of the radiator.
bmc69
I'm the anomaly. I put in a 351, and had to switch from a 180* thermostat to a 190 just so I would do a proper "break-in" on the motor. .
Actually, having a 190 cool better than a 180 and MUCH better than a 160 is not the anamoly; quite the opposite - its normal. My 408 temp would completely 'run away' with either a 160 or no stat at all..it would get away from me on the trails with a 180 and I finally got it under control with a 195.?:?
Other than that; the OP's list is literally identical to mine in every respect..except I also added an engine oil cooler.
Funny ...the comment about the water wetter; I too saw what 'might' be an improvement there. But certainly nothing like the numbers claimed on the product label.?
Curious question: You said the temp never got 'above 190' while running it hard. ??..that's below what I consider just below the normal temp for my engines with 195-198 normal. I consider 215 'OK'..220+ getting in to the 'worrisome' area and anything over 230 but less than 240 to be 'overheating but not overheated. 250+...overheated. What numbers were you 'fighting' before the upgrades?
bmc69
"Overheating Cured"
Man, you are just TEMPTING fate to smack you in the arse! LOL! ;D
LOL..yeah..VERY good point. Yesterday in the middle of 100+ degree heat wave, I point to the AC unit that cools my shop offices and I brag: "That thing has been cooling this place fer 12 years without a hiccup..and I bought it used!"
Yesterday evening....the unit died.%):mad:
NJB71
Little Silver, NJ
I'm looking to install the BCB 12" derale fan to push some extra air in, not really overheating, but does run 185(dont offroad)-pretty reasonable price, easy install? and did u buy an adjustable temp or a simple on/off switch version?
bmc69
Why would you go to all that trouble when you are running so cold?? ?:?
I installed that fan as the pusher in my 408-c trail rig and I turn it on when the temp gets to about 220. IT is the best option for good CFM that still fits ..but only barely and not with the factory hood latch. All that has to be stripped out and use hood pins insteafd.
ManTruck
I totally agree with the numbers and the ratings stated above. Been there and done that while sweating bullets all the time. Finally rebuilt/refreshed the motor and found nothing unusual but made some cam changes and timing a little different. No problems.
NC-Fordguy
NC-Fordguy
I agree with the water wetter comment. I seriously doubt the claim of 10 degrees cooler. It may have helped, maybee it didn't. I do believe it does help in something turnin 6k rpms without a fan, but for the 8 dollars it cost, it was a worthwhile shot.
As far as temps....first couple of times the radiator started puking around 240(highest read on my aftermarket guages) sometimes with steam venting out. This was with the 195 degree thermostat. I'd see 230 with the 180 degree thermostat and at that temp would just shut the truck off, pop the hood and let it cycle a couple times before heading off again. The valve clatter was always a good tell tale sign to turn off the truck
Various parts were installed in between these incidents, but once I'd see 225 I'd shut it off as I wasn't going to risk blowing a head gasket or cracking a block just to see how hot it would get.
I'm hoping this thread doesn't turn into what temp thermostat should be run, mechanical vs. electric fans or stock water pump vs hi-flow. Plenty of threads for that along with associated arguements. I'm simply sharing what I did to get my bronco to run at temps that I am comfortable with.
And fortunately I no longer have to listen from the jeep guys I wheel with "when are you going to fix that overheating Ford crap"
As stated before, the smaller water pump pulley and fixed blade fan were the last parts to be installed and IMO had the most impacting effect on my overheating issue.
bmc69
No..I hear ya loud and clear on that. The only part that was quite different from what fixed mine was the t-stat selection..everything else matched perfect.;)
NC-Fordguy
NC-Fordguy
Since we're on the curiousity mode, What did you use for an engine oil cooler? Some sort of remote oil filter with an oil cooler in-line? That was going to be my next step. In my experience oil temps usually run 10-20 degrees hotter than coolent temps. I'm thinking that's the difference between our thermostat differences.
ken75ranger
Troy, NY
I've seen 5-6 rigs get a 10 degree drop using water wetter. I also saw 2 where it made no difference at all. Guys that run 230 degrees on the trail but otherwise normal I always advise them to try water wetter first.
bmc69
No..I added the oil cooler after I got through with the tests and measurements that pointed me to the corect T-stat and raddy configuration. I got so frustrated with the continuing overheating that I broke the problem down and set up temp instrumentation and tackled the problem as an engineer rather than as a garage mechanic. The results did surprise me...but she's been rock solid in the tmps department for years since. Oh..and the water wetter ..long gone a few flushes ago and never added back since. :p
I'm running a 9" Derale flat-plate oil cooler w/fan. Since I'm running a Cleveland, I have the external oil bypass line that the Windsors do not have..and that is what is routed through the oil cooler. With that arrangement, roughly half of the oil from the pump is being routed through the cooler..the other half is not.
To be honest..I see more benefit in my oil pressure gage than my temp gage from running the oil cooler. When the engine is red hot during a long hard nasty rock pile attempt, the oil cooler clearly buys me some extra psi on the oil gage compared to when it was not installed.
NJB71
Little Silver, NJ
yep....learn something new everyday, jason actually was very helpful(as always) and told me EFI should run 195 average, so I am going to forgo the derale for now, I think my best bet is to get the compartment to breath better, either reroute my air intake or add WH screens on the fenders
