I posted early and now have caught up. Great info out there. I have a couple questions...
Chuck...Questions...
I have the spal 16" fan...Noisy as hell...Is your 7 blade mechanical fan loud like was posted earlier. The noise of the spal is driving me to change as much as the heat issue.
I have a 4 core staggered WH rad with the spal with no shroud. I do get hot on the highway, but it is not nearly as bad as crawling long steady hills. I have the same problem as the original post states. But get this, I was over heating on a snow run with the temp out at 20 degrees. When I say over heating I was hitting 220- 225. I even put snow on the top of the rad. I was working the enigine damn hard...up hill slipping and sliding etc. Anyway, I will check your 11 listed items first. I will also add the 2 inch body lift plate for better air flow. But, I want to get back to a mechanical fan and was thinking of your 7 blade. Long way to get to this question, but what shroud have you found works best...stock? How big in diameter is the 7 blade fan. Does it fit in the stock shroud?
Also, was thinking of putting a fan in front to assist like you said. Does the spal push...I don't know and thought you might know. Just reverse the hot wire???
Also a bit of info for everyone. I found a cheap aluminum rad at summit that looks like it would work in an EB...I am not recommending it or endorsing it, but the price was good and is about the right size. I know other EBer's which have installed it, but have no feedback at all. Anyone?? NON Epoxy HOWE RAD FOR $199.00. Might need to fab a bit, but much cheaper.
summit
Part number: HRE-342A Chuck any opinions on it?
