- Joined
- Nov 3, 2003
- Messages
- 49,436
Some of these suggestions look familiar.![]()
Yep, sure do. But now there's a new audience.
Hey Paul!So THAT's where your dash went.
Funny too, how much more substantial and intimidating a factory harness looks when it's still stuffed under the dash, as opposed to sitting there on a table.
Almost wimpy when you see it that way.
Although, I do like the way Ford (and probably the other O.E.'s too) did the splices.
Their method: Take wires... Jumble together... Twist, solder, crimp... Then wad the whole thing in a big cube of rubber!
Not necessarily pretty, but VERY durable, and weather-tight even after 40 years.
The splices were about the only things not completely melted on a friend's '69.
Eric pointed out a new headlight switch but I can't remember, for sure about the ignition. I will let you all know how the switches look when they reassemble it.I dont know about the Painless harness, but when i bought the centech harness it gave a new ignition switch.which is all fine but I wasnt able to use the stock crome ignition ring. I think that is something that should be added for the people with less mods and more of a stock look.
