I had a local shop install my Painless wiring harness on my 73 Bronco while I was in California for 10 days. Got it back with only the fuel gauge not reading, take it back they swapped 2 wires and now the fuel gauge works; during the installation, the front turn signal lights (grill) were fried after hookup so they had to get new ones sent to them to finish the job after they discovered a ground after completing the installation; they were working prior to the harness install.
However, tonight I go to get in it and the battery is dead (been driving it since last Saturday afternoon; don't know how old the battery is since the date circles are not marked, I bought the Bronco in January 2016). I do not have the original alternator (it only has one wire coming from it; see pics). It came with this "one wire" when I bought it (reading previous threads, it appears that even 1 wire alt's have 3 wires coming from the alt. However, I do remember only 1 wire coming from the alt prior to the new harness).
I did notice that prior to the new harness, my ammeter read + (charging) when I was driving it. After the install, it was reading - (discharging).
I have attached pics of the wiring. It looks like the wires from the voltage regulator are just turned back and taped into themselves; I do not recall what/where they were routed prior to the new harness.
My questions:
1. did the battery go dead because they did not hook up the other voltage regulator wires?
2. How do I correct the situation
3. What kind of alternator is this? (It has a serpentine belt system, "reverse water pump" (the radiator hoses are on the wrong side from original).
My questions:
