- Aug 24, 2006
- 1,229
Hello,
So I purchased the Painless Wiring Bronco Specific kit from one of the local sources that ryhmes with Mild Corses I just started the install and so far it is as about as straight forward as one could hope. I rebuilt my dash, upgraded to the True One Wire alternator from the same Mild Corses vendor... so to speak... and I got to the part of the install dealing with the Volt Meter... also new from that vendor. The kit is set up for the stock Ampmeter and the wires are pre run.
According to the instruction for the new Volt Meter, I will run a separate wire off the positive side and not use the one included in the wiring harness.
Question is what do I do with the wire that is already part of the kit? It is spliced into another wire so removing it completely is not an option.
I am not an electrical guy by any means so please respond with small words and maybe a drawing in crayon
