While tearing down my engine to fix the head gasket issue (see thread)
http://classicbroncos.com/forums/showthread.php?t=266011
I noticed I was sucking some oil into the intake via the PCV valve in the rear of my GT40 lower intake. My gt40 lower does have the baffle on the bottom. I do not have the small Crankcase Breather Element in the intake but have one on order. Could this be the issue?
Also, I'm running 2 PCV valves as the van valve covers I'm using had the PCV in it. I'm getting no oil from the PCV in the valve cover.
I have each PCV valve hooked up to a separate vacuum source on the upper intake. I'm pulling air into the engine via the other valve cover oil filler neck.
Is it possible I'm pulling too much vacuum?
Tim
Tim
