And the voltage will vary over time and during use too. So what you may find as 9v initially, might go down to 6v as the wire heats up from use.
Heat is resistance, and resistance is heat. Hence the heat-resistant jacket around the resistor wire under the dash and the fact that most of it's length is run outside of the taped section of the harness.
As they age with time you might see an increase in overall resistance in that circuit too. Connections get loose or corroded, wire strands deteriorate, etcetera.
So if you don't always see the same voltage at the coil of an old car that you expect, or that you saw on another car of the same model even, that might be what's at work.
