Pinion Preload
cjjhalfcab
Oologah, OK _
Merry Christmas to all of you; I'm not on much these days, but do have a quick question about preload on a 9" I'm building. Set the preload a few months ago on it, and I swear it was around 25ish inch pounds (new bearings), but tore it back down today to put a Truetrac in it and decided to double check it. I'm now getting around 14-15 in/lbs with the seal installed - is that going to be safe? I'd much rather it be around 20 or more, but hate like hell to tear it back apart and pull some shim out of it (went solid spacer). If that is too loose I'll bite the bullet and pull it back apart. Thanks for any help.
EPB72
Pleasant Hill, CA
Generaly 13-16 in lbs on new bearings and on used 6-8 ,,,,, don;t see the need to change ,, if no issues
JB Fab
Did you put any miles on it since the initial set-up?
JB Fab
I would double check the yoke nut torque, then recheck your preload.
C
cjjhalfcab
Oologah, OK _
Thanks. What are you using for the nut torque? Can't remember off the top of my head what I used before, but it seems like figures online are all over the place.
C
cjjhalfcab
Oologah, OK _
I use 200 ft-lbs
OK - just went and put the torque wrench on it again at 220 ft/lbs, and getting right at 15 in/lbs, trending towards maybe 16 with the seal. I might just go with it unless you think that's a bit loose.
That's with an old Snapon "Torque-O-Meter" dial type; using a cheapie Chinese beam-type I'm getting about 17.5 in/lbs.
JB Fab
I consider my myself to be pretty careful about this type of stuff and I would run it, now that you confirmed you didn't have any torque creep.
