pinon angle
22213evl
Rio Rancho N.M.
hey guys I got A ? about driveshaft, pinon angle. I installed a AA rear output shaft housing from WH on the dana 20 (after exploding the stock one) now I have a vibration in the rearend when running down the road (only when under power not when off the gas) I figured it was the changed angle since the AA housing and shaft are 1.5" longer than stock took out the 4% shims and replaced with 6% shims seemed to help slightly (let me also say since the output shaft change I have blown up 4 ujoints and a r driveshft) so I went to harbor freight and picked up an angle finder, on realitivly flat ground it shows 24% angle when stuck to the d-shaft any advice, opinions, ect, would be app, thanks
Viperwolf1
electron whisperer
Off topic but you don't have much slip joint compression left on that driveshaft.
75bronco08
sublimity,oregon
take and cut your spring pads lose and set the pinion 1-2 degrees more than the drive shaft w cv style drive line.done this on many times on my bronco and jeeps no more vibrations.
To be honest those don't means squat.
You need to reference the operating shafts. The engine is not level in the truck. So comparing the angle of the body to the driveshaft doesn't mean a thing. For checking the CV angle you need to measure the output shaft angle of the transfer case.
Then the other angle is the operating angle of the rear U-joint. Which should only be a degree or two.
The actual angle compared to the body or the ground is not important, it is the angle of the 2 shafts to each other that matters.
22213evl
22213evl
Rio Rancho N.M.
first off, oleguy we didn't send our guy's off in PLASTIC JEEPS. second my wheelin buddy has a cj5 with an amc 401 in it he's alright. I'm mostly talkin about mall krawlers, an such. third ease up I'm not burnin the flag here,
22213evl
22213evl
Rio Rancho N.M.
ok slip joint, yeah it sucks but that is the only one i have for now (stock lenght) and the motor in my f-150 just died so the bronco is my only transpo right now :( no wheelin till new driveshaft gets here. also not the problem cause the other shaft had vibration too
22213evl
22213evl
Rio Rancho N.M.
ok angle coming out of tcase 5 angle at pinon yoke 20 I think this might be a problem Suggestions (remember I have no money )
Socal Tom
San Diego, CA
The short slip yoke could be part of your problem. Like Bowsher says, you need to read the tech article on driveshaft angles. Measure the angle at the pinion, and then the angle at the driveshaft, and you want to measure the difference between the two.
To
a67and77
Albuq.
I had the same problem after installing another lift on my 67. The drive shaft was to short and has some slop in the splines as well. Changed to a longer shaft and corrected the problem. Thinking about putting some shims on it.
pinon angle 20 driveshaft 24
24-20=4° of pinion angle.
That should be fine, a degree or two less is prefered but there have been worse come out of the factory at times
24-5=19° of CV angle.
That is a little steep, but has been known to live. This is where a CV can take steeper angles then a simgle U-joint and still run smooth.
That is if I am reading your numbers right.
Cheap fix, take the lift kit out of it.
Needed fix, shorten that driveshaft, when it bottoms out it is very hard on parts ranging from U-joints, CV joints, transfer case and rear ends. Driving on streets isn't necessarly nice as you may think. one dip in the road can cycle the whole suspension while a simple trip on a trail may rock it side to side with nearly no vertical travel in the center. Thus more chance of bottoming the driveshaft on the road then on the trail
22213evl
22213evl
Rio Rancho N.M.
one more time, the driveshaft that is in the pic is only a SPARE I blew up the other one and am waiting on the replacement. thank you to all who have given links, and advice. you have confirmed what I was thinking. (driveshaft angle too steep) due to 1.5" longer tcase output shaft housing. as my other truck is currently doa, I cannot at this time reposition my spring perches. so I will try some diff shims and let you know what happens. THANKS AGAIN FOR ALL THE HELP
TOM
dnewman9
This is slightly off topic but if you rotate the rear end up to fix this, it definitely applies.
Anyone know how much you can rotate the rear end up if you cut the pads before you run into an oiling problem on 9" rears? Is this even a concern here?
Dennis
